Servo questions
Old Feb 6, 2005 | 05:43 PM
CAMMIN03''s Avatar
Default Servo questions
Do I need the Corvette Servo, and a 1-2 servo??
Old Feb 6, 2005 | 06:06 PM
jxaxsxoxn's Avatar
Depends on whats in there now and what kind of 1-2 shifts you want.
and a 1-2 servo
There is no 1-2 servo, there is a 1-2 accumulator. It can use different springs to alter the shift feel.
Your question isn't very specific.
Old Feb 6, 2005 | 08:21 PM
CAMMIN03''s Avatar
I just had seen that on a trans website..
I ordered
Trans-go shift kit...
Corvette Servo
Alum Accum Piston
Trans-go Valve body
Is there anything else I might need?
Old Feb 6, 2005 | 10:11 PM
jxaxsxoxn's Avatar
Sounds like you got it, the aluminum piston replaces the one thats usually plastic.
Depending on brand the servo and accumulators don't usually come with the sealing rings.
What is this?
Trans-go Valve body
They don't sell a valve body that I know of. Got a link?
Old Feb 7, 2005 | 12:31 AM
CAMMIN03''s Avatar
http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMEWN%3AIT
CAMMIN03''s Avatar
I meant valve body plate
Old Feb 7, 2005 | 11:52 AM
Faze2183's Avatar
those plates work like a charm
Old Feb 7, 2005 | 01:28 PM
studlybilly's Avatar
I'm using a 1-2 Super Servo and a 4th apply servo, but it depends on what drive-ability your looking for? Corvette Servo is a nice clean shifting servo, nothing to aggressive.
Old Feb 7, 2005 | 08:31 PM
Faze2183's Avatar
what does the 4th applu servo do?? i just got one and im waitin to put it in...harder shifts or????
Old Feb 7, 2005 | 09:19 PM
jxaxsxoxn's Avatar
It's the same theory as the second gear servo for second gear, it has more apply area to apply the band in fourth.
Good if you do a lot of towing I guess or if for some reason you're shifting 3-4 at the track.
A corvette servo and blocked 4th accumulator seem to work well for everything I've worked on.
Old Feb 7, 2005 | 10:51 PM
Faze2183's Avatar
oh so its mainly for towing???
Old Feb 7, 2005 | 11:03 PM
jxaxsxoxn's Avatar
Well no, it's mainly for increasing holding power of the band in fourth gear.
Old Feb 7, 2005 | 11:27 PM
Faze2183's Avatar
so in return it holdin the band does it shift better or???
Old Feb 8, 2005 | 05:52 AM
jxaxsxoxn's Avatar
No, it's designed to make it shift like ****. What do you think.
What does the better second gear servo do? think about it.
And if you have no clue than why the hell did you get it?
Old Feb 8, 2005 | 08:10 AM
Increased Servo's are not for grocery shopping use, I'm using a 4th apply because I do intend to race from a roll so I will be smashing my trans into OD more then likely when doing so. Just go with the Corvette Servo, no offense, but it doesnt seem like you know enough about it to recognize the difference in the first place. Do NOT use a 4th apply, just use the vette servo.
Old Feb 9, 2005 | 04:38 AM
Faze2183's Avatar
damm man sorry for askin a question...lates forums
Old Feb 9, 2005 | 04:40 AM
Faze2183's Avatar
i know the diffrence but some times its hard for me to understand...my mind doesnt operate that fast lol....id like harder firmer shifts, thats why i started with the servos im just waitin to put her in before my next track day i havent taken this truck out there yet....
btw man i wasnt offend by what you had to say but by the other guy...he didnt have to be a smart *** about it....mainly for those tryin to learn...
Old Feb 9, 2005 | 09:40 AM
jimmyblue's Avatar
Moderator
I've been told that all LS1 F-bodies have the
"Corvette servo" from the factory?
Old Feb 9, 2005 | 05:22 PM
BURN'EM's Avatar
Check out www.4l60-e.com that will answer your questions. I have superior/ Fairbanks billet servos shift nice firm barks third with no juice at 80. Of course that is with sumitomo all seasons.
Old Feb 10, 2005 | 02:21 AM
CAMMIN03''s Avatar
I have a truck....
