Will an LS1 4L60e work with an LT1 - are they the same?
I am 100% positive that they won't bolt up you would have to get an adapter for the bell housing bolt pattern. Plus I'm not for sure but I believe the ls1 2 piece case is a little bigger then the LT1's 1 piece case.
I had been damaged alot of 4l60E gears , so the main differences are :-
1- bell housing
2- torque converter
3- elctrical differences( sensors , harness connect )
4- input and also the output shaft
5- gears drams (the lt1 have the same 700R gear dums)
6-gear oil pump.
there are 1 or 2 things also that i dont remember
1- bell housing
2- torque converter
6-gear oil pump.
