ST-3500 keep hitting the limiter!!!!!!
Old Nov 24, 2001 | 05:29 AM
TransAm2002's Avatar
Default ST-3500 keep hitting the limiter!!!!!!
So far, I love this convertor and have had some good races with it, but everytime I race, it hits the rev limiter in the top if second gear. Then it falls on its face. Does anyone know what could be causing this? Thanks.
Old Nov 24, 2001 | 07:33 AM
227Hawk's Avatar
Default Re: ST-3500 keep hitting the limiter!!!!!!
Your choice hpp or reprogram,raise shift
rev limiter alter shift point's
only way's i know see ya later <img src="graemlins/burnout.gif" border="0" alt="[Burnout]" />
Old Nov 24, 2001 | 10:15 AM
Ragtop 99's Avatar
Your motor is spinning up faster then before, causing it to hit the limiter.
Before you get a HPP3, double check you fluid level and if you race in "D" try putting the shifter in "OD" and see if the problem continues.
Old Nov 24, 2001 | 11:30 AM
Kristi's Avatar
There is no HPP3 out for the '02's yet, unfortunately. Ed Wright programming is just about the only option. My car does the exact same thing. I have not tried racing it in OD yet. My opinion is that it's just a result of screwed up shift points. My 1-2 shift is way too early and that 2-3 rev limiter banging is killing me. Plus it just pisses you off to hear it do that every pass!!! <img src="images/icons/mad.gif" border="0">
Trevor just got Ed Wright programming and he says his is doing perfectly now.
Old Nov 24, 2001 | 03:34 PM
EvilLS1's Avatar
Yep, same here... Does it sometimes in "D", but putting it in "OD" solved the problem.
Old Nov 24, 2001 | 11:07 PM
Red Raider's Avatar
when you say put the trans in OD instead of D,do you take off in OD or 1st then shift to OD,THANKS
this is my 1st auto f body so Im new to everything with the auto
Old Nov 25, 2001 | 12:07 AM
WILWAXU's Avatar
Believe it or not... the OD thing works. My stock converter in my 01 Formula did the same thing.. in D put it in OD and would go away.
Old Nov 25, 2001 | 12:22 AM
WILWAXU's Avatar
If you have a Pontiac it's D and 3 (start in D). For a Camaro it's OD and D (start in OD).
Old Nov 25, 2001 | 05:16 AM
I guess I will have to try that. I hope that works, I really do not want to mess with any programing.
Old Nov 27, 2001 | 02:32 AM
SCZ28's Avatar
Are any of you running higher than stock shift points with the ST3500? Where does it shift with the stock points?
Old Nov 27, 2001 | 02:37 AM
EvilLS1's Avatar
[quote]Originally posted by SCZ28:
<strong>Are any of you running higher than stock shift points with the ST3500? Where does it shift with the stock points?</strong><hr></blockquote>
I am... +2 on the 1-2 and +3 on the 2-3 if I remember correctly.
It shifted at around 5900-6000 with the stock shift points.
Old Nov 27, 2001 | 03:01 AM
Well, I tried it, and so far is works. It shifts fine!! I can't wait to go to the track this Saturday!!! <img src="graemlins/burnout.gif" border="0" alt="[Burnout]" />
Old Nov 27, 2001 | 07:21 AM
Raughammer's Avatar
D(irecto)r Pepper
Well, what do you know...
Heck I just learned something. Thanks guys. <img src="images/icons/cool.gif" border="0">
It actually helped? (stunned) wow.
Old Nov 27, 2001 | 08:50 AM
Trevor @ Texas Speed & Perf.'s Avatar
LS1Tech Premium Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
Wow, you learn something new everyday! I wonder why it will bang the limiter in D but not in OD. Mine usually shifted okay, but the last time out it was banging the limiter. It didn't bother me to get custom tuning because the LOW 1-2 shift point and torque mgt. were killing my ET. I can't begin to tell you the night and day difference with proper shift points and no tq. mgt.! <img src="graemlins/fluffy.gif" border="0" alt="[Fluffy]" />
__________________
Old Nov 27, 2001 | 10:47 AM
Kristi's Avatar
(shaking) Must.... go.... to..... track. <img src="images/icons/grin.gif" border="0">
I KNOW I will get my 7.9x and 12.5x if I don't bang the limiter. Plus, I can bracket race with renewed consistency!!! This is so exciting!
Old Nov 28, 2001 | 03:41 AM
Damn, it did it again, in overdrive tonight. I hope it works this Saturday at the track or I will be pissed!! <img src="images/icons/smile.gif" border="0">
Old Nov 28, 2001 | 09:22 AM
gwj's Avatar
gwj
From: Live Oak, FL - in the woods where the creatures lurk.
I hit the 1-2 limiter at -2 shift point settings.
Or so I thought.I knew it was pulling timing. Yesterday I set -3 on the 1-2 shift and monitored only rpm,speed,gear. After running up to the end of 1st it bogged then picked up. According to Autotap shows it actually shifted 1-2 then downshifted to 1st (@ 42 mph) then did the normal upshift back to 2nd again.
Anyone ever experience anything like this?
Before today it seemed I just needed to adjust shift points, now I'm not sure WTF is happening.
Looks like on one end TM is killing me, on the other way the lower shift settings confusing the computer/trans.
[ November 28, 2001: Message edited by: gwj ]</p>
Old Nov 28, 2001 | 09:51 AM
Kristi's Avatar
Brandon-
Are you saying it DID hit the rev limiter in OD the last time you ran it?
My bubble is burst before I even made it to the track (SIIIIGH) <img src="images/icons/frown.gif" border="0">
Old Nov 28, 2001 | 09:45 PM
Kristi,
Yes it did!! <img src="images/icons/frown.gif" border="0">
Old Nov 29, 2001 | 08:57 AM
SidewayZ-28's Avatar
[quote]Originally posted by TransAm2002:
<strong>Damn, it did it again, in overdrive tonight. I hope it works this Saturday at the track or I will be pissed!! <img src="images/icons/smile.gif" border="0"> </strong><hr></blockquote>
Check your fluid!! btw if you are, how are you checking it?
