Question about 3.73's paired with a SY3500
Re: Question about 3.73's paired with a SY3500
I don't have that combo but let me suggest:
1) your dyno #'s should be pretty much unchanged. 3.73s may cause a slight loss of HP on the dyno, but the SY's efficency will make that up.
2) you should be able to achieve your desired track gains, especially if you have good tires.
LS1 Tech Administrator
The SY 3500 should be worth .4-.5 reduction in ET and the 3.73 gears will be worth another tenth. That's .5-.6 gain...not bad.
If you haven't bought the SY3500 yet, you may also want to consider the ST3500 converter. You'll drop .5-.6 in the quarter with 3.23 gears alone...plus keep your gas mileage and dollars from the gear swap (plus programming costs). You can always add 3.73 gears later, but on the ST3500, they'd only be worth about .05 in ET (that's HALF a tenth).
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
No dyno numbers here, but it is a GREAT combo on the street. I can pull cars like a **** off the line with pretty good traction rolling into it. Tires still totally go up in smoke with the sy3500 and 3.73's. Really good shift extension too, some say its a week converter, but its awesome with 3.73's. Dont regret this at all.
-dan
-dan
I currently have 3.23 gears and am in the process of adding 3.73 gears and a SY3500 over the next few months. I figure I will net about 5-6 tenths by swapping for the above combo.
Does anyone have track or dyno numbers from doing the exact swap?
Thanks
Chris <img src="graemlins/burnout.gif" border="0" alt="[Burnout]" />
Thanks
