Install page for a TH350 swap....
Old Nov 29, 2001 | 01:04 AM
Slow Z28's Avatar
Default Install page for a TH350 swap....
anyone got a link to one? or atleast a parts list of what's exactly needed? if not when i do the swap i'd be willing to do this. i'd just need a little help from someone who's done an install page before for like a cam or whatnot to help me determine what exactly is needed. thanks for any help or advice.
Chris
Old Nov 29, 2001 | 07:18 PM
steve's Avatar
Default Re: Install page for a TH350 swap....
well, lemme give it a try
1: trans mounts fine with 5 bolts. you will lose the upper most bolt and the two bottom bolts that go into the oil pan.
2: converters bolts up fine to the stock flex plate.
3: make sure you get a shifter that you like, works, and is sent with a shifetr cable as you can modify the stock cable to work but it wont be right.
4: if you dont get a 9 inch tail housing, you will have to have adriveshaft made..47 1/4 inch center to center if my memory serves me right.
5: if you get a trans with a tranny brake, you will need a rear end of course as i dont think the stock one will hold long.
6: the stock torque arm can be used, ive done it so have others, but in a case such as this it makes better sense to just get a good aftermarket heavy duty torque arm so you set the pinion angle easier.
7: the shifter will mount if you dissasemble the stock console and do some "pre assembly" so you can get a general idea where it will need to go. i have had to use 1/16-1/8th inch aluminum plate to mnount the shifter on then mount the plate to the floor on most of my installs. works out fine.
8: you will need to just fork out the $$ for a lokar dip stick for the swap. braided stainless line 30 inches long works.
9: get a shift light for a manual valve body tranny. the last car i did revs so quick you aint got time to look at the tach...ie: it all over the rev limiter before you know it.
i know i am miising some small stuff, but thats the general stuff right?
steve frank
Old Nov 29, 2001 | 08:02 PM
Slow Z28's Avatar
will the lack of the two bolts going intot he oil pan cause any type of leaking? especially with a power adder would that allow pressure to escape and possibly blow a gasket or something along those lines? thanks again.
Chris
Old Nov 29, 2001 | 08:03 PM
Slow Z28's Avatar
also, what's with the 9" tail housing? how do i knw if i have that? sorry for the stupid question, just starting to look into this, been a manual tranny guy all my life.
Chris
Old Nov 29, 2001 | 08:11 PM
Marty's Avatar
Steve,
I was wondering on the 350 swap do you just go buy any th 350 and have it built up or is there a certain one for our cars? I know there has got to be a cheaper one than the 3000+$ yank. Where can i get one? Where did you get yours? Who do you recommend?
Marty <img src="graemlins/burnout.gif" border="0" alt="[Burnout]" />
[ November 29, 2001: Message edited by: Marty ]</p>
Old Nov 29, 2001 | 08:37 PM
steve's Avatar
there are two types of tail shafts.
a six inch one and a 9 inch one.
i use the six incher and have shafts made to fit the car that will hold a transbrake launch.
no oil will leak and we have had good luck with over 4000 rpm launches so i dont feel the extra bolt missing on top makes much diff.
the stock vss switch can be made to fit the tail shaft, i have done it.
marty, if your really interested, come by and lets talk. i use trans king for there stuff. call and talk to bob, he is a transmission monster. knows his stuff real good.
some have had good luck with jw and other people. t350's and 400's are not hard to build.
when you are said and done, you will have about 2000-2100 in the swap.
then you can sell your stock parts and recoupe some of the money
also, a small amount of plate steel or aluminum will need to be used for the tranny mount. not hard to do once you get it all up there and look.
steve frank
Old Nov 29, 2001 | 08:46 PM
Slow Z28's Avatar
[quote]Originally posted by steve:
<strong>
steve frank</strong><hr></blockquote>
is this if you don't use an aftermarket crossmember?
also, how do you measure the tailshaft length? and either way you need a custom driveshaft though right?
Chris
Old Nov 29, 2001 | 08:53 PM
steve's Avatar
this is with the stock cross member.
the tails shaft bolts to the rear of the tranny. four bolts.measure from there to the end of the tranny.
steve frank
Old Nov 29, 2001 | 09:12 PM
Slow Z28's Avatar
ok, sweet. just checked and i have the 9" housing, so what is needed driveshaft wise for that?
Chris
Old Nov 29, 2001 | 09:16 PM
Marty's Avatar
<strong>
As soon as I get the money i'll let ya know. Andre ever find a tranny? Hey I might have to get you to install the dynatechs I just bought. Me and brad are gonna give it a shot first but if we can't do it I'll give ya a call. How hard is it?
Marty
Old Nov 29, 2001 | 09:38 PM
steve's Avatar
easy.
steve frank
