02 WS6 need a flexplate upgrade with convertor?
Old Mar 24, 2005 | 12:57 PM
Jeff2002WS6's Avatar
Default 02 WS6 need a flexplate upgrade with convertor?
I've started looking into the convertor upgrade again since spring is here. I saw a couple of threads here recently where a person claimed the 01/02 had weak flexplates and to replace it with the TCI one or one off a 98. I did a search but didn't really find much information. Is this true and which one would you chose? Where to get a 98 flexplate?
Old Mar 24, 2005 | 01:00 PM
Ragtop 99's Avatar
the older flexplates do seem to be stronger. I would not worry about it unless you plan to make a lot more HP than stock.
Old Mar 24, 2005 | 05:02 PM
I hope to some day get a LG X2 cam and maybe toss on some spray. I want to be able to run high 11s.
Old Mar 24, 2005 | 08:40 PM
jimmyblue's Avatar
Moderator
I did the swap because I had seen several postings
about cracks on our model years, they didn't seem
to be restricted to high-HP cars, and I was ready to
do the converter swap at the time. If you're going
to have the tranny off you might as well just do it.
I got a virgin '98 from valvegod at a good price.
Old Mar 24, 2005 | 09:30 PM
Blacker's Avatar
The TCI Flexplates are expensive. I was considering buying one until I found out the 98's have a decent flexplate. I would try to find one of those first.
Old Mar 24, 2005 | 10:18 PM
tuff's Avatar
8 SEC SLOPPY SHOT!!!
Is a 99 as good as a 98? If so i have one i would sell.
Old Mar 25, 2005 | 12:13 AM
LS1LT1's Avatar
Question
And for that matter, are the 2000s the same as '98s?
Old Mar 25, 2005 | 12:50 PM
jimmyblue's Avatar
Moderator
https://ls1tech.com/forums/showthrea...lexplate+crack
Old Mar 25, 2005 | 12:58 PM
LS1LT1's Avatar
Thumbs up
Thanks dude.
Old Mar 25, 2005 | 07:17 PM
mikemodano9c's Avatar
i destroyed my stock flexplate...sounded horrible...
Old Mar 25, 2005 | 10:06 PM
GETSOMZ28's Avatar
I am getting ready to do a verter swap, does any sponsor carry the 98 flexplate??
Old Mar 25, 2005 | 10:35 PM
Blacker's Avatar
Hit up the Parts Wanted Section.
Old Mar 26, 2005 | 07:26 AM
tuff's Avatar
I think i covered the parts wanted.Maybe he is looking for new old stock.
Old Mar 26, 2005 | 11:21 AM
GETSOMZ28's Avatar
Yank's got some!
Thanks guys.
Old Mar 26, 2005 | 12:24 PM
LS1s R US's Avatar
Tci isin't to expensive for a flex plate new stock one probably cost more!Thunder has a special going for $179.99 until 3/27/05!
Old Mar 27, 2005 | 06:46 PM
Thanks for the info guys. Sounds like a new flexplate will have to be in the plans as well.
