Flexplate nicks back of engine at start up????
Old Mar 31, 2005 | 02:54 PM
99'Formula's Avatar
Default Flexplate nicks back of engine at start up????
It's wierd because whenever I start up the car cold, the flexplate nikcs the back of the engine then goes away after its warm. Is there a spacer to put behind the flexplate to move it away from the motor? What can I do?
Ike
BTW, I have a TH-400 and it has done it for a while, just wanting to fix it b/c it is now getting on my nerves.
Old Apr 1, 2005 | 03:17 PM
99'Formula's Avatar
no one can chime in?
Old Apr 1, 2005 | 04:22 PM
scottyballs's Avatar
what about using washers?
Old Apr 1, 2005 | 05:52 PM
S_J_H's Avatar
are you sure it's not the converter bolt heads hitting the rear cover bolts?
I had to grind my bolt heads down a little to clear the rear cover bolts.
Steve
Old Apr 1, 2005 | 07:06 PM
99'Formula's Avatar
I have 1 washer between the felxplate and convertor.
Old Apr 1, 2005 | 07:07 PM
99'Formula's Avatar
Steve
I'll have to take a look at that. But why would it only hit when its cold?
Old Apr 1, 2005 | 11:09 PM
S_J_H's Avatar
Probably just thermal expansion. Take a good look at the converter bolt heads. Paint the heads of the converter bolts with something and start it up. If it's hitting the bolts you'll see where it rubbed the paint off.
I assume you already checked to make sure the converter bolts are tight.
Old Apr 3, 2005 | 01:02 AM
LT1PWRD's Avatar
Two thaughts i have are:
(1) Too much crank end play (thrust bearing worn out) this used to be a stick car right?
(2) Flex plate warped (and wobbles more whn.under the extra stress of the fluids having a thicker viscosity whn cold
My .02, let us know
92
0
Old Apr 3, 2005 | 04:49 PM
99'Formula's Avatar
My .02, let us know
92
0
Yeah my car used to be a stick. # 2 makes alot of sence so I think I'm going to go ahead a get a TCI Flexplate and see what happens.
