2 to 3 shift problem
It sounds like the 3-4 clutch clearance could be too loose. I have experienced that problem and torn a trans down to fix only that, it worked great afterwards.
The clearance was well in stock range at .090, I was told to set it between .030 and .040.
That worked.
Double check the teflon rings on the input shaft when you put it back together, and use new rings.. I'm with this guy. Mine did the same thing. I tuned it out.
I'm still on my stock tranny. My rebuild kit is sitting in the floor waiting to be installed. My tranny shifts fine under normal everyday driving but put your foot in it and 1-2 strong 2-3 holds/hesitates before it shifts.
