all th400 people inside:need help
Old Apr 10, 2005 | 12:51 PM
sprayinss's Avatar
Unhappy all th400 people inside:need help
ok guys went from m6 to th400,with 4k stahl,car runs good and all just wont turn up like it should real sluggish,the only thing left i havent hooked back up is speedometer,will this not being hooked up affect pcm functions,any help is appreciated,i am bout to go crazy please help thanks,
Old Apr 10, 2005 | 01:48 PM
JPSartre12's Avatar
I've got a TH400 and ~4K stall TC and I haven't had a working speedometer in years. The only thing it affects in the cruise control from what I can see. I have a Scanmaster and the EGR and carbon canister are disabled as well.
If it's sluggish, maybe you're running too rich. Check your O2's for fouling or maybe you need a dynotune. I'm not sure how well a M6 PCM program does with a TH400. My throttle response improved tremendously after the A/F ratio was flatlined at ~12.5.
Old Apr 10, 2005 | 01:54 PM
sprayinss's Avatar
the car is a 98,o2s look fine and everything else does too,i have hp tuners and have checked all of that,any more ideas,anyone thanks
Old Apr 10, 2005 | 07:21 PM
sprayinss's Avatar
sum1 please shed sum light on this please thanks
Old Apr 13, 2005 | 12:18 PM
GrannySShifting's Avatar
email me and I can give you a hand
Old Apr 13, 2005 | 07:56 PM
99'Formula's Avatar
When I did mine(m6 to th400) it ran like **** and was really rich. Tuned it and now it hauls ***. I don't know why it did that either.
Old Apr 13, 2005 | 09:40 PM
redbandit98's Avatar
is the tranny kicking down (if your running an auto valvebody) or are you running a manual vb? if your still running an auto valvebody youll need to hook up a kickdown switch to let the tranny know your on the gas..just a thought....
Old Apr 13, 2005 | 09:45 PM
sprayinss's Avatar
no kickdown needed its a manual reverse valve body,**** it ur self,i am still puzzled
