Which rebuild kit
Hughes Performance Transmission Rebuild Kits
TCI Pro Super Transmission Overhaul Kits
B&M TransKits Th400 rebuild
which one will work with my current setup
my set up is
Built TH400
Vig 3600 non/lock
TCI Flex plate
Reverse Manual valve body
Trans Brake
B/M shifter
is itas easy as just goin to buy this kit and putting it my transmission
You don't need any valve body parts, maybe not even the gaskets that come in a kit. You might have to reuse your old valve body gaskets or contact the manufacturer for some gaskets.
If it were my transmission I'd got to www.bulkpart.com and get a gasket set (they call it a overhaul kit, it includes all the gaskets, sealing rings, etc) and seperate clutch plates and bands. Sand your steels.
Save a whole bunch of money by not buying stuff you either don't need or can't use.
