Poly Trans Mount good idea?
Question is, if I get under there Monday and see that it is the mount, should I replace it with a poly? I've already got poly motor mounts, and I don't know if I want any more vibration. Would a good replacement rubber mount hold up for a little while? I'm on a stock stall, BTW.
John
my window welded stocker is PERFECT after sooooo many hard launches w/nittos.
minimal vibration, can be found at any auto paint store (it is used for putting car windshields in).
= costs 15$ and takes a couple days to dry...
i SWEAR the window weld thing should be a sticky. i don't see how anybody puts up with those poly mounts- i had mine for 2 days before i took it out.
Mike
use the same mount-never a problem
