What Stall For My Setup???
I WAS TOLD THAT WITH THE 1.8'S THAT IT WILL PUT THE LIFT AT AROUND .600 WHAT WOULD BE A GOOD STALL SPEED FOR THAT??... IT WILL BE DRIVEN ON THE STREET BUT IT IS NOT MY DAILY DRIVER
http://www.converter.cc/wizard/wizard2.htm
THANKS FOR THE INFO..... CAM CLAIMS TO MAKE POWER FROM 1800 THROUGH 6500...
I'd get the car together and tuned in and get it on a dyno. Select the proper stall based on the powerband, vehicle purpose, weight and gears used. Dave and Mike at Yank can get you very close to perfect, but if you can provide all the data needed, they can nail it everytime.
I hope this helps. Good luck!
Personally I wouldn't change the rear gears until you install a 12 bolt. I ran the Yank ST3500 with the 222/566 cam (Stage2 heads) and my stock 3.23s with incredible results, but I had traction with true drag slicks.
BTW- The large caps indicates that you are yelling. It offends some people.
Good luck!
Good luck!
right now i just want the car running and cant afford to put in a 12 bolt for at least another year, the car has been down for 6 months last year and again since january this year.
after i have the car tuned i will decide on what stall...
thanks for the info
hopefully should be done with in a few weeks along with tunning guess i should also get some sfc's so i dont do any frame damage
