cant do a burnout???!!!
Old Apr 12, 2005 | 10:00 PM
Havok2's Avatar
Default cant do a burnout???!!!
just installed a 3400 2.0 fuddle racing stall in my car...
now i try to test it out.
i press the brake, stops at about 2400, then i continue to press the gas as far down to do a burnout and it wont go past 2400 rpms? it wont let me do a burnout? what could it be? it did one before the stall went in?
Old Apr 13, 2005 | 08:25 AM
scottyballs's Avatar
sounds like your in 2nd gear I had this problum a few times pull it down in first gear and try again, its not going to stall at 3400rpm's either you will need a line lock and some sticky azz tires to stall it to 3000
Old Apr 13, 2005 | 09:07 AM
GregWS6&z28's Avatar
hummm, I dunno about that. I just stalled my 3800 to 3400rpms at the track using nothing but my brakes and nitto tires
Old Apr 13, 2005 | 10:19 AM
Havok2's Avatar
2nd gear?
it does this at all times...i have tried about 10 times to do a burnout, and still nothing!
rpms get stuck at around 2400.....i dont want the stall to go higher if it cant, what i want to do is a burn out, how am i supposed to warm up my tires at the track?!
Old Apr 13, 2005 | 01:34 PM
CamaroSS's Avatar
Originally Posted by GreenGoblin956
2nd gear?
Your problem is in the tunning. The car still thinks it has a stock converter in it, and you are shifting into second gear because of the rpm you are at. Put the car in first and try, otherwise get a tune.....or tell fuddle racing about it. I honestly think that the tune is the problem, and do not recomend you drive it hard until you change the shift points.
~Kevin
Old Apr 13, 2005 | 01:56 PM
jimmyblue's Avatar
Moderator
At part throttle shifting needs MPH threshold to be exceeded.
Now, the stock vehicle tune has some lame-*** shiftpoints
and the first bit of wheelspin may kick you up into 2nd, never
to recover (unless you get back below 11MPH). Too, a throttle
that hasn't been worked over or has too much cable slack or
whatever, may not put your TPS to the magic WOT % that
invokes the WOT upshift limits, maybe leaves you at the 90%
part throttle shiftpoints in the table.
2400 fot-stall on a nominal 3400 does seem low and the 2.0
STR should let you roast 'em. I would check underneath for
some install-related stupidity like a messed up wire or hanging
connector (like the CKP sensor which is right there where the
work was done). Do you have any codes showing up or any
other reduced-power symptoms?
Did the build sheet come with yours, and does it indicate
the numbers you asked for? Hopefully nobody mis-wrote
your order and got you a 2400 rather than 3400... that
would suck, though I don't expect this would be the case.
Old Apr 13, 2005 | 08:35 PM
Havok2's Avatar
i did email john, to get it situated.
my friend has a ssf 3500 stall and he has no problems burning out or nothing!
according to john, my car should stall to about 3000, and it is a 3400 stall.
Old Apr 14, 2005 | 08:15 PM
Sandmann120's Avatar
Shut your traction control off. J/K
Old Apr 15, 2005 | 10:48 AM
Havok2's Avatar
LOL if it were only that easy!!
