i need help!!! converter problems
Old Apr 21, 2005 | 11:30 AM
02WSSICK's Avatar
Question i need help!!! converter problems
my car is a 2002 ta, please somebody has any idea what is wrong with the car. the car ran a 12.76 at 105.23 m/h with a 1.775 60ft. mods at that time:
air lid
3200 vig
et streets
slp loud/m cat back
transgo
stock tanny and 3.23 gears.
now it has a cam on the 230-240 duration, 90mm fast intake, 90mm t/b, kooks 1 7/8-2 to 3 1/2 collector, 3600 vig with 2.5 str, same tires time same gear, and the car ran 12.069 at 111.39 m/h with a 1.685 60ft.
im guessing is something wrong with the converter cause the seems a lot slower on the top end than what is supposed to do, i dont think this converter is very efficient at all, please any suggestion will help!!!
Old Apr 21, 2005 | 11:40 AM
boomcase's Avatar
That vig will feel softer uptop , that would be the trade off but you have a big cam big intake big throttle body , with stock heads , that doesnt seem to be the right combo in my opiniun. I think you got some big flowing parts on your car inwhich do not need. Bigger isnt always better. I had 216/220 cam with boltons and a tci 3800 converter that would run 11.80s at 112mph in 80*temps ..
Old Apr 21, 2005 | 12:29 PM
02WSSICK's Avatar
other opinions?????
should i go with a different converter?
i got a really good deal on those parts i couldnt passed it, also i going with 150 tnt so, i need a converter that is gonna work with my current set up.
you guys dont think is a kindda low m/h ? anyone?
Old Apr 21, 2005 | 03:27 PM
boomcase's Avatar
whats your 1/8 mile mph
Old Apr 21, 2005 | 03:36 PM
JNorris's Avatar
Moderator
The vig3600 is a good converter. I do not think that is your problem.
Have you done any weight reduction?
What is your race weight?
Where do you race?
Your 105.23 looks a little low but it all depends on where you race and weather conditions. My ET will vary .5-.8 from winter to summer.
You trapped 6mph higher and dropped your ET by .7. Not too bad.
John
02WSSICK's Avatar
7.684 @ 91.18 M/h
Old Apr 21, 2005 | 03:39 PM
boomcase's Avatar
Have You Had The Car Tuned........
Old Apr 21, 2005 | 03:42 PM
02WSSICK's Avatar
the car weighs around 3460 pounds with my inside, i got these times at baytown, and the last run i made at the track there was alot of humidity.
tanx!
Old Apr 21, 2005 | 03:44 PM
02WSSICK's Avatar
yes, i got the car tuned last week, my tuner said my m/p seems kinda low.
Old Apr 21, 2005 | 03:50 PM
boomcase's Avatar
what did it put down for hp , i had my car tuned and it put down 342 at the wheels and weighed in at 3576 with me in it . I still think the parts are to big , you want to have velocity as well as volume..
Old Apr 21, 2005 | 04:44 PM
02WSSICK's Avatar
the car put down 380 rwhp, but we couldnt get a torque reading cause of the converter.
Old Apr 21, 2005 | 05:26 PM
JNorris's Avatar
Moderator
I agree. Put some good high flowing heads on there and it will really fly. Some 3.73 gears will help to.
John
Old Apr 24, 2005 | 05:27 PM
88GT&69ss's Avatar
With the converter locked up his car made over 420 rwhp at 6700 rpm. The curve was still going up.
Old Apr 24, 2005 | 05:52 PM
16again's Avatar
Stock heads is one problem the other problem is the large 1 7/8 headers. On my stock engine Corvette I installed 1 7/8 headers and it slowed down a ton, went down to 1 3/4 headers and ran much quicker. As the others have said I don't think you have an issue with the converter. Good Luck
Bob
