Best way to mount tranny cooler?
Old Dec 13, 2001 | 05:46 PM
turbo's Avatar
Default Best way to mount tranny cooler?
I just bought the B&B tranny cooler. Dont know whats the best way to mount it? Vertically, horizontally? What?
Casey
Old Dec 13, 2001 | 06:44 PM
SAINT WS6's Avatar
Default Re: Best way to mount tranny cooler?
mines just sitting in front of my radiator, its horizontal
Old Dec 13, 2001 | 06:49 PM
turbo's Avatar
Thats how I had my old one.
Do you have yours with the inlet/outlet facing down?
Just thought I heard some people mount it vertically with the b&m.
Thanks
Casey
Old Dec 13, 2001 | 08:14 PM
gwj's Avatar
gwj
From: Live Oak, FL - in the woods where the creatures lurk.
I initially had my B&M shoved up about as far as I could get it, but the radiator had to be repaired after a crash. I decided to re-install it all the way down on pass side so as to block less air between the front "shroud" and the condensor. Mine is installed with the fittings facing up, and I dremeled a hole in the plastic at the top/side passenger side big enough for the lines to fit through and snaked them between the batt and the radiator.
Old Dec 14, 2001 | 04:11 AM
WEASEL's Avatar
www.ls1.com/ls1forum/Forum1/HTML/021850.html
I did mine the same as shown in this post. I may try to make it sturdier later on but it has worked just fine so far with countless brushes over parking blocks with my car lowered.
It's a pretty easy install once you decide where your're gonna mount it. This place is especially good for people with the FTRA already.
<img src="gr_stretch.gif" border="0">
Old Dec 14, 2001 | 07:50 AM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
Mine has the tubes exiting down. The unit is mounted in front of the condenser to the support frame. It’s the first thing that hits the air.
Old Dec 15, 2001 | 02:22 PM
SAINT WS6's Avatar
It's on the passenger side of the radiator and the inlet is facing upwards. I don't think it really matters which way the tubing faces.
