HELP(asap), Fuddle TC installed = problems
I emailed asking for an estimate on the shipment timeframe but havent got a reply yet... I'm guessing these guys got a lot of orders with the GP price as it is.
Something to keep in mind...
Sometimes it makes me wonder how much the STOCK tune from GM varies from one car to the next. Say corvette tune vs F-body tune, or GTO tune vs F-body tune........Or hell for that matter, how much it varies from like cars, say 98 F-body vs 02 F-body......
I just don't see it being possible to have a 3000+ converter on a stock tune and not have SOME KIND of issues with the stock programing....
to minimum slip / squealage and harmonize the lock /
unlock with the shiftpoints. The higher the stall speed,
the more you'll notice the lock/unlock at points below
it. On a stock car the stall is so low you usually just
don't.
At the track, who cares, it's all or nothing. Around town
an untuned car with a racing converter can be a little
bit Flintstones Meet The Jetsons.
TCC PWM so that it's always 98% duty cycle. This
helps. But 98% of not-enough (that is the wimped-out
line pressure at light throttle, courtesy of Da General)
is not-enough. Still full-timing the TCC PWM really
shrinks the slip-prone region. You can do this with
hardware or tuning.
Basic fact is, a 10" converter clutch is not going to hold
the same torque as an 11" clutch, at the same pressure,
all other things being equal.
i dunno wtf is wrong... i got the car back the begining of the month and 6 days later the trans blew 3-4 clutch pack... got the car back last friday and now lost all forward gears... this car is pissing me off. I think you said that your tranny was or is new or rebuilt recently.. you ought to see if it has a warranty. hopefully it does so you can get it fixed now and the verter problem fixed as well.
Im hoping this doesnt happen to me..
Chummmma,
When did the converter start having the problems? Was it happening before your transmission went out?
Did you ship the part out?
Chummmma,
the last trans lasted 6 days htis one lasted 4 days!!!
