Car shakes at 25-30 mph... TC problem?
1. Has to do with custom tuning on shift points or TC lock up?
2. Is my tranny finally starting to show signs of breaking down?
3. My TC crapping out on me somehow?
Car runs fine any other time and even when racing.. only messes up when at those certain speeds..
If anyone can help me.. I'd appreciate it big time! I don't know what it could be! Thanks !!
I just went through a similar problem, only mine did this at 50 mph. If I tried to slowly accelerate from that point, the car just shook like a futhermucker, and didnt go anywhere.. was fine if I mashed the gas pedal at 50, but didn't want to do anything if I feathered the pedal.
It took me a week to find the problem.
Now, this is going to sound completely retarded, I know.
But my problem was one loose spark plug wire. I fixed that, the problem went away. (Wtf?! How does that have any affect on this, I don't know..)
Check your spark plugs. All of them. Even the hard to get one, the furthest one on the passenger side (thats the one that was the culprit in my case).
Its a 01 and i know new models had TM probs.
My converter used to lock and unlock extremely fast making a nasty vibration noise, just as some of you have described - under light load only at certain speeds. Once I got the fuel trims correct I didnt have that problem anymore.
I used a MAFT to get my LT's to zero.
and lock it back up when they go away. If the
misfire is load related (like mixture, weak spark,
etc.) then this can have you cycling in & out of
lock.
not generating enough spark for whatever the reason may be
