how much to fix a Solenoid?
Old Jun 15, 2005 | 09:24 PM
4mula's Avatar
Default how much to fix a Solenoid?
my second gear sticks only at wot, other than that, the car goes threw the gears fine
Old Jun 16, 2005 | 09:24 AM
4mula's Avatar
also do i have to drop the trans or just the pan??
Old Jun 16, 2005 | 10:34 AM
Z'mnypit's Avatar
I think the last one I bought was $21 at the dealership. No need to drop the trans, just the pan is needed. Then unplug the solenoid, get a flathead screwdriver & remove the clip holding it in place, slide it out & put the new one in. It very simple. The only problem is that there are only two shift solenoids, each one is for two gears. I think the drivers side was 1st & 4th & the one on the Pass side was 2nd & 3rd. If im wrong then someone please correct me.
Old Jun 16, 2005 | 11:49 AM
4mula's Avatar
maybe ill just replace both.
thanks!!
Old Jun 17, 2005 | 07:20 PM
radz282003's Avatar
Replace both while your in there
Old Jun 17, 2005 | 11:43 PM
4mula's Avatar
above will be my plan
Old Jun 17, 2005 | 11:57 PM
jlrz28's Avatar
10 Second Fun Car
Had problems with mine before the OD would go out and kick it into "limp mode" ended up replacing both and then also changed the filter.
Old Jun 18, 2005 | 01:12 PM
mrr23's Avatar
if it shifts fine normally, then it won't be the solenoids. while you have the pan down, take the 2nd gear accumulator piston out and see if it is cracked. the 2nd gear housing is the round tower looking thing with 3 bolts holding located on the rear passenger side of the trans. the piston is made out of plastic and is prone to splitting at the center where it rides on the pin. i had to replace it on mine. i also ended up replacing the forward accumulator which is on the driver's rear of the valve body.
Old Jun 18, 2005 | 03:20 PM
4mula's Avatar
it drives fine when i drive it normally.
when i floor it, it wont go into 3rd
Old Jul 1, 2005 | 08:44 AM
Kirby's Avatar
Sorry to do this but I am having problems and can't get any useful help from anyone. Here is the link to my thread. Please help me out. https://ls1tech.com/forums/showthrea...shift+solenoid
