Highspeed tranny accident. Info please.
Old Jun 19, 2005 | 05:55 AM
LS1FIRE's Avatar
Default Highspeed tranny accident. Info please.
Hello I was on the highway going a good amount of speed up a hill incline. The car was in over drive. I tried to place the shifter into third but i accidently shifted into 2nd and banged the limiter. The the car seems to be acting normal. What damage did i do? The tranny temps did not rise very high only to about 160. i hope everthing will be okay.
Old Jun 19, 2005 | 08:17 AM
cablebandit's Avatar
if you didnt hurt the motor, you are fine. I have taken my tranny to 7300 rpms for 10 passes when I had 3.73 gears. If, anything you might have bent a few pushrods. If everything seems fine, keep on trucking!!!
Old Jun 19, 2005 | 01:26 PM
1QuickT-A's Avatar
Yeah, let it ride man! You didnt hurt anything.. Mine bangs the limiter all the time when I'm sprayin it and shes still workin just fine!
Old Jun 19, 2005 | 08:10 PM
LS1FIRE's Avatar
Thanks for the replys. I was worried about it because i knew i was well over the speed of maxing out 2nd gear when i accdiently downshifted into 2nd trying to go to third from overdrive. i hope my tranny and my bottom end is ok. The motor doenst make any ticking our unordinary noises. I plan on swaping out the heads at the end of this month anyway.
Once again thank you everyone for reading.
