What does it take to go th350
Old Jul 17, 2005 | 08:32 AM
Ronnie Abene's Avatar
Default What does it take to go th350
What does it take to install a TH350 in a 2002 f-body? Can someone give the complete process? Thanks
Old Jul 17, 2005 | 11:27 AM
SUX2BU's Avatar
auto or 6 speed?
Old Jul 17, 2005 | 04:48 PM
NosboySS's Avatar
Tranny itself 800+
torque converter specifically for that application 400+
98 flex plate or a TCI SFI flex plate <179
BMR t-350 crossmember 179
Depending on the output shaft length, a new driveshaft <400
Shifter and custom installation 100+
Tranny cooler would be a good ieda 100+
Pedals if you dont have an auto already.
Speedo ring and sensor if you get the right housing(or the free ABS speedo creation) <150
If you dont want ses lights, some computer work by either you or a shop
I did a complete converision for about 2,700(ouch i hate adding stuff up like that!)
Well, i guess 1400 out of pocket after selling the built 6 spd.
posted by spdfreakls1 not nossboy
Log out boy!
Old Aug 2, 2005 | 01:12 AM
Formulized94's Avatar
What is the reason you need the 98 flexplate?
Old Aug 2, 2005 | 01:59 AM
SUX2BU's Avatar
it has two sets of holes one for a regular LS1 converter and one set for the old school converters ie th350/th400.
Old Aug 2, 2005 | 07:40 PM
Strahley's Avatar
My th350 has a 9" tailhousing, the stock aluminum driveshaft fits perfectly
You might need a torque arm adapter. I bought B&M's 30299 piece, it worked fine. If you have a chasis mounted torque arm you won't need it
The biggest problem I ran into was the shifter & linkage. Still trying to tweak it to work 100% correctly
Old Aug 2, 2005 | 11:21 PM
NosboySS's Avatar
My buddy(nossboy here) had the same problem, some gears were perfect, when he got to the other side, it was off, never got it perfect. My mega shifter in mine didnt really need any adjustment. 30 seconds. It seems to be hit or miss. <Y biggest problem was waiting 5 weeks for BMR to send me out a crossmember, and the driveshaft guy making it too long lol.
spdfreakls1
Old Aug 2, 2005 | 11:25 PM
Strahley's Avatar
I bought a shorter linkage, be here Thursday. The one I have now is 4 foot, it's WAY too big. I have to loop half of it around the crossmember! The one I bought is 2 foot, I should be able to make it a straight shot. If not, there's a guy local here who can tweak it for me. Wish me luck
Old Aug 3, 2005 | 12:06 AM
SUX2BU's Avatar
thats weird my B&M pro stick works perfect with the cable it came with. i think it was 4 feet.
Old Aug 3, 2005 | 01:04 AM
I have been hearing something about the th350 torque converter pilot bushing not fitting into the ls1 crank? is this so?
Old Aug 3, 2005 | 01:49 AM
SUX2BU's Avatar
Yeah the regular 350 bushing is too short. when you get your converter just tell them its going in an LS1 and they will make the bushing longer so it will fit.
Old Aug 3, 2005 | 10:07 PM
is there anything to do when i already have a standard th350 converter that i want to use?
Old Aug 3, 2005 | 10:21 PM
SUX2BU's Avatar
yeah there is some spacer that goes between the converter and the flywheel. it comes with longer flywheel bolts too.
Old Aug 3, 2005 | 10:25 PM
SUX2BU's Avatar
www.400raptor.com about half way down the page
#LS1-700. Crankshaft spacer to install an early type TH400 / TH350 transmission on a LS1 type motor. Six longer flywheel bolts included. The LS1 flywheel is reused. The flywheel goes on first then the spacer. The torque converter bolt holes in your flywheel must be elongated to fit your non-LS1 torque converter bolt circle. Cost $75.00
Qty 12345
