Poll: Lets talk converter gains
Old Jan 18, 2002 | 10:31 AM
Supertrapped's Avatar
Speed freak
Default Poll: Lets talk converter gains
I just wanna kinda take a poll and see what everybody has and gained. I'll go first <img src="gr_stretch.gif" border="0">
Converter type?...ST3500
Gear size?...2:73
Loose/tight?...little loose
Tranny rebuilt?...no
Tranny cooler installed?...no <img src="gr_emb.gif" border="0">
Shift kit installed?...no
Custom programming/HTPP?...no
Any SES codes?...no
Did you test the converter at track right after install?...yes
Times with converter (and/or gear) change only
Best ET before converter?...13.19 @ 106.9 2.01 60ft
Best ET after converter?...12.21 @ 110.8 1.71 60ft
Overall thoughts on your choice of converter?
This converter kicks serious ***. .98 drop in ET aint too bad <img src="gr_grin.gif" border="0"> . Someday I might switch to a TP4400....but not anytime soon.
[ January 18, 2002: Message edited by: DevilBird ]</p>
Old Jan 18, 2002 | 10:48 AM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
Default Re: Poll: Lets talk converter gains
Converter type: SY3500
Gear size: 3.23
Loose/tight: Just fine for me
Tranny rebuild: Not yet, but coming next month or two (just preventative upgrade for upcoming motor build-up, stock tranny is still doing fine)
Tranny cooler: Yes, B&M 16,000gvw supercooler. Temps stay around 185 cruising (summer) and 200 after a hard beating (summer)
Shift kit: No.
Custom Programming or HPP3: Yes, custom tune from MTI (LS1 edit) No more TM!!! <img src="gr_stretch.gif" border="0">
SES codes: No, never before or after custom tune
I installed my ‘verter before I ever took the car to the track, so I don’t have a before and after. But with just an air lid, cat back exhaust, common suspension upgrades (SFCs, STB, LCAs, PHB), and BFG DRs I ran a best of 12.69 (1.69 60ft) with only 3000 miles on the clock! My common 60 foot times were more in the 1.7X range though.
I love this ‘verter from a roll. It preformed better from a roll than my friends equally modded vig3200 car did. It’s not at all too loose for me and I love the ease of launch on the street with the low STR. All around I love this ‘verter and I will probably be keeping it in permanatly, unless I ever upgrade to a SY4000. The car is now going through a build-up, so that SY4000 might be in order...
[ January 18, 2002: Message edited by: RPM WS6 ]</p>
Old Jan 18, 2002 | 01:11 PM
mmiller's Avatar
Texas Director
Converter type?...ST-3500
Gear size?...3.23
Loose/tight?...just a little loose
Tranny rebuilt?...no, totally stock
Tranny cooler installed?...Yes, B&M 19,000 GVW
Custom programming/HPP?...Yes, HPP
Any SES codes?...yes, I leave the tranny in "D" when driving under 50 MPH and have not gotten any more SES codes
Reduction in ET with converter almost .7!
Absolutely awesome converter in terms of performance gain. Shaving off almost .7 is mind boggling. The only complaint I have against the ST-3500 is the SES light occaisionally if you leave it in "OD" driving around town.
Old Jan 18, 2002 | 01:52 PM
Trevor @ Texas Speed & Perf.'s Avatar
LS1Tech Premium Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
Converter type?...Vig 3200
Gear size?...3.73:1 (yet to be run at a sticky track)
Loose/tight?...perfect street/strip converter
Tranny cooler installed?...yes
Shift kit installed?...yes
Custom programming/HTPP?...Ed Wright
Any SES codes?...no; never had any before the tuning either that were converter-related
Did you test the converter at track right after install?...not on my SS I didn't; I saw over .6 from this converter in my T/A, though. I would expect my gain to be right at the same in my SS.
I think it's the absolute best street/strip converter that Precision Ind. makes for our cars. I could definitely handle more stall, but I'm not going to do any upgrading just yet. I'm hoping to see some 1.5 60' times and 11's with the 3.73's and a raceweight right at 3,640#.
__________________
Old Jan 18, 2002 | 02:53 PM
monSSter1191's Avatar
Converter type? ST3500
Gear size? 3.73
Loose/tight? A little looser than I'd like
Tranny rebuilt? No
Tranny cooler installed? B&M 19,000 GVW
Shift kit installed? No
Custom programming/HTPP? HPP (Only used for gears)
Any SES codes? No
Did you test the converter at track right after install? Yes
Times with converter (and/or gear) change only:
Best ET before converter? 13.68 @ 103 with a 60' of 2.10
Best ET after converter? 12.80 @ 106.7 with a 60' of 1.7x
Overall thoughts on your choice of converter? Huge gain at the track, definitely the best mod you can buy for an A4. Picking up almost 9 tenths from a single mod that costs less than a thousand dollars installed is hard to match.
Old Jan 18, 2002 | 03:08 PM
CHRISPY's Avatar
Here is my comparo <img src="gr_stretch.gif" border="0">
Was M6 with 3.73's
Best time with cats on the car
12.62@116mph 1.91 sixty on slicks
Switched to Yank4L70 tranny and TP4400 converter
4.11 gears
With only HALF throttle in first gear
11.70@116.5mph and a 1.67 sixty
Car has 11.40's EASY in it.
So I gained 9 tenths while having to give it half throttle through first.
And will probably have a net gain of around 1.2 seconds with hook <img src="gr_stretch.gif" border="0">
Chris
Old Jan 18, 2002 | 03:09 PM
Patman's Avatar
OK, I'm sold, the very first mod (after tires) for my LT1 is going to be a convertor!! I'm gonna go with the Vigilante 2800. What kinds of results have you LS1 owners seen with this convertor?
Old Jan 18, 2002 | 03:50 PM
NASSty01's Avatar
Gear size?...3:23
Tranny cooler installed?...no B&M 24,000 sitting in the garage
Any SES codes?...yes, leave it in OD driving around town it throws code every now and then.
Best ET before converter?...8.53@86.78mph 1.8960ft on F1's
Best ET after converter?...8.27@86.67mph 1.86 60ft on F1's!
This convertor ROCKS! I dropped .3 off my 1/8 mile ET!! with street tires and totally babied it off the line. Very similar weather for both runs. Can't wait for my ET streets to come in!
Rick
[ January 18, 2002: Message edited by: NASSty01 ]</p>
Old Jan 18, 2002 | 05:32 PM
FormulaWS6's Avatar
Gear size?...3:23
Tranny cooler installed?... B&M 19,000
Custom programming/HTPP?...HPP3 for 2-3 shift
Any SES codes?...NEVER
Best ET before converter?...13.2@106 mph 2.01 60ft on DRs
Best ET after converter?...12.4@108 mph 1.66 60ft on ET Streets
Old Jan 18, 2002 | 06:30 PM
Loco's Avatar
Converter type? Yank TP 4500
Gear size? ...stock 3.32
Loose/tight? ...VERY LOOSE
Tranny rebuilt? ...no
Tranny cooler installed? ...yes B&M
Shift kit installed? ...no
Custom programming/HTPP? ...HPP (shift pts)
Any SES codes? ...YES
Did you test the converter at track right after install? ...yes
...13.2x @ 106.x 2.1 60ft on ET Streets
Best ET after converter? ...12.7 @ 109 1.7x 60ft on ET Streets
I love it to death. Ran a 12.0 @ 111 (TM is hurting me bad!) with a 1.65 60ft and I spun on that run. Hoping for a 1.5x 60ft soon!
I'm getting constant SES codes. Other than that, I'm really happy with it.
[ January 18, 2002: Message edited by: Loco ]</p>
Old Jan 18, 2002 | 06:55 PM
[quote]Originally posted by Patman:
<strong>OK, I'm sold, the very first mod (after tires) for my LT1 is going to be a convertor!! I'm gonna go with the Vigilante 2800. What kinds of results have you LS1 owners seen with this convertor?</strong><hr></blockquote>
I shaved off exactly .5 with the Vig 2800 in my T/A. I soon upgraded to the Vig 3200. <img src="gr_stretch.gif" border="0">
__________________
Old Jan 20, 2002 | 05:10 AM
TR's Avatar
TR
I'm sure you guys knew I would be showing up in this thread sooner or later. So, without further delay, here are my thoughts on the 2 converters I have gone thru on my '01 SS.
Converter #1:
Converter type?
- Yank ST3500
Gear size?
- 3.23
Loose/tight?
- Very Loose
Tranny rebuilt?
- No
- B&M 24K GVW
- No
- Yes, HPP3 @ 25%
Any SES codes?
- All the time, even if I drive in 3rd and shift to 4th. Don't even THINK about this converter for an '01+ if you live in the hills!
- Yes
Best ET before converter?...13.21
Best ET after converter?...12.75
The ST3500 was a big (and expen$ive) mistake on my '01.
Converter #2
Converter type?
- Precision Industries Vigilante 3200
Gear size?
- 3.23
Loose/tight?
- Not bad at all. No, it's not "perfect", but what is?
Tranny rebuilt?
- No
- B&M 24K GVW
- No
- Yes, HPP3 @ 25%
Any SES codes?
- None at all, and I drive this converter in 4th gear all the time.
- Yes
- Best ET before converter?...13.21
- Best ET after converter?...12.73
- One of the best performance mods that can be done to an A4 daily-driven car. And I received it in 4 business days, not 4 business months...
(OK, so it really took almost 2 months to receive my "other" converter, but you get the idea)
Old Jan 20, 2002 | 04:37 PM
DriveATransAm's Avatar
Converter type?...Vig3200
Gear size?...3.23
Loose/tight?...little loose for daily driving
Tranny cooler installed?...the biggest B&M one-24K?
Custom programming/HTPP?...hpp for shift points
Any SES codes?...sometimes
Best ET before converter?...12.87 -1.8X 60ft
Best ET after converter?...11.88 @ 114.41 1.55 60ft
excellent converter. went from 12.87 to 11.88 with the converter and a maft. i have a minor bolton car (headers, cutout, lid, ftra, converter, maft). full weight TA (well, heavy skinnies on the front)
60' drop was sweet. 1.55 on NITTOS <img src="gr_stretch.gif" border="0">
great converter for a daily driver.
Old Jan 21, 2002 | 01:56 PM
DóòD's Avatar
Converter type?...VIG3200
Gear size?...2:73
Loose/tight?...No Complaints...
Tranny rebuilt?...nope
Tranny cooler installed?...Yup B&M 19,000 GVW
Shift kit installed?...Yup.
Custom programming/HTPP?...Nope
Any SES codes?...nope
Did you test the converter at track right after install?...yup
Best ET before converter?...13.3 @ 105.9 2.01 60ft On an Ideal day..Ran 13.5's normally
Best ET after converter?...12.80 @ 105.5 1.74 60ft.. Into a 20mph headwind..Hoping for better.
Kick Azzz... Best mod for the $$$'s After debating and various recommendations I went with the Vigilante. 3 washer on Shiftkit makes for some sweet 1-2 shifts.
Old Jan 21, 2002 | 02:07 PM
CHRISPY's Avatar
Patman,
If you are going Vig I would go with the 3200 stall <img src="gr_stretch.gif" border="0">
A lot of people find that converter a good comprimise between street and strip. <img src="gr_grin.gif" border="0">
Chris
Old Jan 21, 2002 | 05:39 PM
flyin red TA's Avatar
Converter type?...PI3200.
Gear size?...3.23.
Loose/tight?...kind of loose.
Tranny rebuilt?...no.
Tranny cooler installed?...yes.
Shift kit installed?...3 washer transgo.
Custom programming/HTPP?...hpp3 for shift points.
Any SES codes?...yes. only from lockup switch.
Best ET before converter?...13.3 when bone stock.
Best ET after converter?...12.2 @ 110 1.66 or 1.68, can't remember. Installed a lot of other stuff at the same time.
[b]Overall thoughts on your choice of converter?
Sometimes I wish I would have maybe gone to the PI3600 or a SY4000. For now it works, so I'll keep it.
Old Jan 21, 2002 | 06:30 PM
Dope's Avatar
Converter type?...Y3000
Gear size?...3.23
Loose/tight?...tight
Tranny cooler installed?...Yes, B&M 24k
Any SES codes?...no
Best ET before converter?...13.29 @ 106.29, 2.16 60ft
Best ET after converter?...13.33 @ 106.67, 2.21 60ft
Needs more tire.
Dope
Old Jan 21, 2002 | 06:50 PM
MrTransAm's Avatar
Converter type?...Hughes 3000
Gear size?...3.23
Loose/tight?...loose
Tranny cooler installed?...yes, B&M supercooler
Shift kit installed?...yes, B&M TransPak
Any SES codes?...no
Best ET before converter?...13.7@ 103.2 2.1 60ft
Best ET after converter?...12.7@ 106.8 1.7 60ft
Awesome mod for the money. Still very streetable too which is what I wanted to keep.
Old Jan 22, 2002 | 10:13 PM
cobrakillerta's Avatar
WOW DEVILBIRD , those are some NIIICE gains just form the converter. <img src="graemlins/gr_hail.gif" border="0" alt="[hail]" />
That's my next mod, i have 3.23's
My car is a dailydriver...
what converter shoudl i get?
thanx in advance!
Old Jan 23, 2002 | 01:00 AM
MMI Z28's Avatar
any side effects to the stall? any tranny problems? rear end?
-Watson
01 SOM Z28
