Stupid problem...HELP!!!
Old Aug 4, 2005 | 02:46 AM
8banger's Avatar
Default Stupid problem...HELP!!!
I put my tranny back up after the torque converter install. Everything's good, all the lines connected, shifter cable, etc., etc. and everything's bolted up though. The problem: every time you turn the crank, the torque converter bolts pop out, and they pop out for enough to get stuck. Why do they do this? How can I fix it? PLEASE help. Thank you.
Old Aug 5, 2005 | 02:21 PM
2001whiteSS6spd's Avatar
The flywheel might be on backwards if you did ever take it off
Old Aug 5, 2005 | 02:45 PM
8banger's Avatar
I never removed it. I'm thinking that since so many of the bolts are the same diameter, I may have grabbed one that was too long since I had them all bunched together.
Old Aug 5, 2005 | 02:59 PM
john kilgore's Avatar
Default bolts
you may be putting sae bolts into a metric thread.
Old Aug 6, 2005 | 07:25 AM
8banger's Avatar
****. Good point. I'll have to check that out this afternoon.
