Torque Managment????
Old Aug 10, 2005 | 05:46 PM
mustgofasster's Avatar
Default Torque Managment????
Hey guys I just got my car out the shop yesterday. 24k Tranny cooler, transgo shift kit, vig 3200 converter. Here is the problem at WOT right AFTER it hits second gear the car stops going fast and sounds like its not geting any gas. But if I take my foot off the gas for just a second then hurry up and get back on it then it does not do that. I was wondering if its a fuel pump problem. no codes
Old Aug 10, 2005 | 06:13 PM
TA4U2NV's Avatar
car does the exact same thing, except i got a stock stall. my converter is going in today. i haven't a clue what it is, but would like to know.
Old Aug 10, 2005 | 06:40 PM
strokedls1's Avatar
Have you turned off the torque management. If you haven't I would.
Old Aug 11, 2005 | 04:21 AM
98A4LS1's Avatar
Should the TM be turned off with stock torque converter?
Old Aug 11, 2005 | 11:12 AM
orion565's Avatar
Default tune?
did you get a tune, it did that before I got my car tunned.
Old Aug 11, 2005 | 11:20 AM
no tune yet!! STOCK TUNE
Old Aug 11, 2005 | 11:23 AM
can a diablo tuner turn off the TM
Old Aug 13, 2005 | 03:14 PM
BubaGumpShrimp's Avatar
it totally is torque management. You need to have it tuned out. From what i know the diablo tuner is able to do it(might need them to send you a new tune in email, than upload it to the diablo). I used ls1 edit. Before i got ls1 edit i had the converter installed and the shift kit installed. The main reason tq management kicks in is cause of harsh shifts that are over the torque limit programmed into the computer. You need to either raise the limit of the torque value or completely remove that part of the programming(which i did).
