WOT in OD
Old Aug 17, 2005 | 12:11 AM
obZidian's Avatar
wat about a high performanc clutch pack? I think i have a 12 disc....
Old Aug 17, 2005 | 01:43 AM
SmokingWS6's Avatar
Don't confuse racing in 4th and shifting into 4th at wot which occours a tad over 130mph or higher depending on gears.
3-4 wot shifts are very hard on the weak clutch pack. Try to limit them as much as possible.
Old Aug 17, 2005 | 01:50 AM
nrayome98TA's Avatar
Yeah w/ my 3.73 rear i shift into 4th at 112 approx. With 2.73 it was like 130.
I'm wishing I had gone 3.42 gears. Thanks for the info guys it helped clear up my question.
Old Aug 17, 2005 | 08:25 AM
StealthFormula's Avatar
can we just buy and install new clutch packs? Im kinda concerned since I go WOT all the time in all gears.
Old Aug 17, 2005 | 09:30 AM
FLeXNuTZ's Avatar
So would a FLP, Rossler, etc. tranny fix this problem? I emailed FLP 3 times about their 4L65e Level 5 tranny being able to withstand WOT downshifts on the street and highway but they never responded. They say it will reliably hold 725 rwhp though so I don't know, maybe they'll hold up fine. Especially if you have bolt-on power levels.
Old Aug 17, 2005 | 10:47 AM
obZidian's Avatar
ok, the stock clutch pack is weak, i know, that was the first thing to go in my old trans. Also, the second gear clutch is also a weak link so avoiding a 4-2 downshift would be advised.
My question is if i have a built trans, with a 12 clutch 3-4 pack, in theory it should hold more. So, would it be still recommendable to do a WOT 3-4 shift.
Also, if no, would it be ok to, right before the 3-4 shift point, reduce tps% to 90% or 85%, shift, than go WOT?
Old Aug 17, 2005 | 11:15 AM
blkZ28spt's Avatar
Even an aftermarket tranny won't fix the weak clutch pack problems. I have the Maximimum Evil (stage 3 by Dr Evil, through LS1 speed) and have only executed one WOT 3-4 shift, and only did that because I didn't realize I was already going that fast until it shifted. I do believe I will make it endure one HIGH speed run in the future though. I also don't do as many 4-2's as I use to. The clutches just don't have enough friction surface area to hold this power for any length of time, and the line pressure doesn't come up as fast as it should in certain situations, etc etc. This is what I have read. My tranny is advertised as being capable of holding 850 hp and 800 lbs of torque when you use a hardened input shaft (which I don't have and don't need for power I'll be making anytime soon) and Larry still said that the people who run them hard regularly (in the 10's) have them refreshed annually with things such as new bands/clutches.
There have been quite a few threads about this and related topics, with some interesting information. Search around and read through them.
Old Aug 17, 2005 | 12:07 PM
CamaroSS's Avatar
That is not possible unless you have modified the internal gearing of the tranny....should still be in the low 130s high 120s...
My friends has 4.10s in his A4 TA and his car runs out of gear in 3rd at 119mph, so a 3.73 should still be in the 120s if not the low 130s.
blkZ28spt's Avatar
I agree that those numbers don't look right at all.
Shift into fourth at 130 with 2.73's? I have 3.23's and made it to about 140 in third.
http://www.f-body.org/gears/
Old Aug 17, 2005 | 12:38 PM
SporkLover's Avatar
makes you wonder if he got his speedo corrected with the new gears
Old Aug 17, 2005 | 03:38 PM
josh99ta's Avatar
Sold The Fun Stuff :(
How is 4-2 any worse on the 2nd gear clutch packs as 1-2 is at WOT? You're getting wear and tear regardless. If you're that worried about your 2nd gear clutch packs dont go WOT at all. The weak link are the OVERDRIVE clutch packs, because overdrive isn't meant to have a ton of holding power like the other gears are. I went 80k miles on the first tranny with 4-2 and 4-3 downshifts EVERY SINGLE DAY. What killed it was 3-4 WOT shifts, and that clutch pack was toast. Everything else was fine. I'm now 45k on the second tranny, plenty of 4-2 and 4-3 WOT downshifts and zero problems. Zero 3-4 WOT shifts and the tranny is living a happy life. I'd like to hear from a reputable tranny builder like Rock-On, TCI, or Yank before I buy into this 4-2 and 4-3 downshift bullshit.
Old Aug 17, 2005 | 05:17 PM
  #32
I am so confused. So is it better to gun in it OD or 3rd gear? Also if the clutch packs go do I need to get a whole new transmission and how much do they run?? I go WOT in all gears every day so Im concerned a little.
Old Aug 17, 2005 | 06:34 PM
  #33
blkZ28spt's Avatar
Doesn't really matter. What matters is not going INTO overdrive at WOT, which would mean having the selector in OD (or D for firebirds) and keeping the pedal on the floor up at ~140 mph.
It's also hard on the tranny to go from 4-2 at WOT, just not as bad as going into OD.
If you really want to know, SEARCH. It has been answered before, I just don't remember it well enough to repeat and get it right.
Old Aug 17, 2005 | 09:22 PM
  #34
thanks^
So say Im doing 40mph in OD and I punch it hard. Is that considered a 4-2 shift? I will now just gun it in 3rd.
Old Aug 17, 2005 | 09:48 PM
  #35
blkZ28spt's Avatar
Actually I believe 3-2 might be worse than 4-2...
I try not to worry about the downshifting too much. If I'm in a situation that calls for it such as passing or running from a roll, I do it, plain and simple. However if I'm just out F-ing around having fun with the car I either give it just enough that it shifts into third and wait till I'm >80 mph before getting the pedal to the floor, slow down enough it shifts into first (<30 mph) or start from a dig.
Old Aug 17, 2005 | 09:56 PM
  #36
cablebandit's Avatar
on 26.1" tires my car does 150 in 3rd (3.23 gear) with the converter locked at 7000rpms so no need to do a wot 3-4 shift. As far as downshifting, i never just floor it while in o/d....i'll gas it enuff to kick down into 3rd and then mat it. I assume you guys are roll racing though or something. i broke either a sprag or planetary...either way it was a hard part failure but my 3/4 clutch pack was still going strong
Old Aug 17, 2005 | 10:22 PM
  #37
RevGTO's Avatar
Pontiacerator
https://ls1tech.com/forums/automatic-transmission/293017-manual-vs-wot-downshifts.html
From James B.:
A 4 to 2 downshift is easier for a 4L60-E to do than a 3-2 downshift. It is a single event of disengaging the 3-4 clutch pack. Downshifting from 3 to 2 has to release the 3-4 clutch pack and engage the band at the same time. There is a valve specifically for doing this just to make sure it doesn't let the engine over-rev trying to pull that off.
Keep in mind that mechanically the 4L60-E is only a 2-speed auto with overdrive.
Old Aug 18, 2005 | 01:14 AM
  #38
speedo is spot on according to radar setup by the highway dept.
I shift at 6000 rpm into 4th at 112-113.
I have all my shifts at approx. 6000 rpm with the hpp3.
Old Aug 18, 2005 | 02:41 AM
  #39
I just did the gear, tire size calculator and it says at 6000 rpm in 3rd I should be at 125.
But my car says 6000 rpm and 113 mph. At 60 mph my speedo is on because they have radar that shows you how fast you're going setup on the side of the highway.
Somethings funky maybe I have my tire size with the hpp3 slightly off and at 60 its on but the higher speed it is off?
How accurate are the stock speedo and tach though?
Old Aug 18, 2005 | 04:55 AM
  #40
Superman09's Avatar
LS1Tech Sponsor
Hey, this is interesting. I drive in D on my TA all the time. Once once have i gone fast enuff to shift it into 4th which i will not do again after reading this. So when i want to go on a high speed run, leave it in 3?
I usually like to cruise at about 25-30 and floor ir from D, this is the 2-1 correct? It friggen plants you and i love it, is this correct? Also at about what speed roll are you at and floor it to do the 4-2 or 3-2? Just curious so i dont do it. While cruising i can never tell what gear im in so i need some MPH help. I have the 3.23's. So i should basically leave it in D when jsut cruising around town, and throw it in 3 on WOT runs, 2-1 downshifts and at the track? Thanks
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
