80E Swappers Need Help
Old Sep 4, 2005 | 12:01 AM
desTRUCKtive's Avatar
Default 80E Swappers Need Help
Just to give you some background: I picked up a 6.0 and an 80E with wiring harness and everything. This is off a 2000 HD truck. I completely swapped everything out, including the wiring harness. Therefore, I did not get the harness kit for the 80E swap.
2) I am throwing a couple of codes P0740 (TCC enable soleniod) and P0785 P0785 (3-2 Shift soleniod) does anyone know why these could be on. I really dont think that the actual soleniods are bad, I think it is a wiring problem. But I did swap the entire harness out thinking that that would be suffecient enough.
I took it around the block and it is not shifting out of first. Can anyone give me some suggestions and where to start.
Old Sep 4, 2005 | 12:16 AM
quicksilverado's Avatar
Are you using the stock pcm? If so you need to program it for the 4l80e.
Old Sep 4, 2005 | 11:18 AM
I do have the stock PCM but I thought that my standards version of Hptuners would handle, I have heard from other replies on performance trucks that i Need someone with the capability of of changing the 80E settings, I guess the standard version will not do this.
Old Sep 6, 2005 | 10:57 PM
Read this thread. Ken at hptuners hooked me up with the basic tuning to get the tranny working properly.
https://ls1tech.com/forums/pcm-diagnostics-tuning/330624-4l80e-swap-programming.html
Old Sep 7, 2005 | 01:42 AM
strokedls1's Avatar
You need to have ken make you a bin file with the 6.0L motor and 80e transmission. There is a difference between the wiring and the program is sending info for a 60e.
