Install of Sub Frame Connectors
Old Feb 5, 2002 | 07:19 AM
Beth's Avatar
Default Install of Sub Frame Connectors
What is the proper way to position the car while installing weld in sub frame connectors?
Also, has anyone cut into the floor and welded this way or just weld to the floor?
Thanks guys!
Old Feb 5, 2002 | 07:26 AM
BIGBOS's Avatar
Default Re: Install of Sub Frame Connectors
The way shops usually do it is to put it on a lift and undo one of the battery cables....I looked at mine close and it looks like they were welded straing to the floor...
They are great to have
Old Feb 5, 2002 | 07:38 AM
Beth's Avatar
I had read somewhere that the car should be sitting on the tires on a lift?
Old Feb 5, 2002 | 07:39 AM
BIGBOS's Avatar
Well I could see where it would be better not to have any of the suspension unloaded....
go to www.installuniversity.com
then go to install documents, they have some stuff there about install SFC's
