stall ?
Old Sep 25, 2005 | 05:32 PM
99midnightZ's Avatar
Default stall ?
i was just wondering what are the basics of a stall and why you use them.how they work and so on. also what brand is the best to get and how do you set it up. thanks for any help!
Old Sep 25, 2005 | 06:37 PM
Roarin_8's Avatar
A stall puts the car in it's powerband extremely quick and when it shifts, keeps the car in the powerband (shift extension). A stall should be one of the first mods for the auto with drag radials of course.
Old Sep 25, 2005 | 08:00 PM
so does the car drive normally or does it launch at the stall for instance...if you have a 3000 stall will the car only go at 3000rpm from drive???or will it remain stock going into drive as soon as shifted...sorry this is really a newbie question but i ahve no idea about stalls
Old Sep 25, 2005 | 08:17 PM
Roarin_8's Avatar
Depends on how much throttle you give it. Mines for instance, the car won't start moving till 1500-2000 RPMs. If I give the car half throttle, she'll jump to 3000-3500 RPMs. Full throttle and she'll "flash" right to 3800-4000 RPMs, the Nitto Drags can't take that kind of hit though and she'll spin for a bit. Depending on your gears, I have 2.73s, will also determine on when the car starts to move. I like it alot and it feels extremely controllable since I can move the car at any RPM past 1500 with the touch of my foot.
Old Sep 25, 2005 | 09:47 PM
so if i had 3:73 what stall size would i want? 3000
Old Sep 25, 2005 | 09:53 PM
s346k's Avatar
asking what stall is like asking what cam. funny thing is, they are DIRECTLY related. what goals do you have for your car? this will determine what stall and gears.
Old Sep 25, 2005 | 09:59 PM
ummm...lets see...well i will eventually throw a turbo on it..that is my main goal..this will happen next winter.but for this winter (while stored) i was wanting to have just a 75-100 shot,gears, build up the stock a4 alittle bit,cam (just a good mild cam)heads,headers,0ry, and any other bolt-ons. just looking to get around 400horse when i spray. thats the goal for this winter...but as everyone knows shyt changes. see this is also my 1st automatic so everything is alot different. all help is appreciated
Old Sep 26, 2005 | 02:13 PM
any help would be awesome? im really wanting to thrown in a stall coverter just dont know what to do?
Old Sep 26, 2005 | 02:30 PM
Roarin_8's Avatar
It's tough to say because you want to go turbo down the road and forced induction doesn't use huge cams. I would personally pick anything in the 3400-3600 range with 3.73s. You'll probably want to change down the road but a converter in that range would be a good start for now.
Old Sep 26, 2005 | 02:37 PM
hmmm.... so what if i just wanted like a 3000 stall, nitrous, NO HEADS OR CAM, and my 3:7s gears...would that be a good street setup? im not wanting to go to the track.maybe i will eventually...but this is mostly street racing and shyt. all the opinions are awesome and thanks for your help
Old Sep 26, 2005 | 02:41 PM
01_ram-air's Avatar
Look at my sig........that's what a stall will do for you! Best mod you can get for an automatic. Mine is a ST4000 Yank.
Old Sep 26, 2005 | 02:59 PM
Roarin_8's Avatar
I hardly go to the track as well. And even with my 2.73s, this converter pulls very nicely.
Old Sep 26, 2005 | 11:08 PM
would gears be too crazy for the street.(not being able to hook up) or with a stall and 3:73 would i be fine??? also roarin you have a 3800 stall...is that too big for stock or do you suggest i get a 3000 too 3500 stall. and what kind?
what about theses
http://www.fuddleracing.com/wst_page7.html
Old Sep 27, 2005 | 11:17 AM
Roarin_8's Avatar
My car is still near stock but you should plan to grow into your mods. Don't wind up getting something that you'll most likely change down the road because the car grew out of it. I would get 3.73s but I'd wait till I change the rear to a 12 bolt.
Old Sep 27, 2005 | 11:26 AM
wait to get a stall?
Old Sep 27, 2005 | 12:26 PM
Roarin_8's Avatar
No I would wait to change my gears after putting a 12bolt in the rear.
Old Sep 27, 2005 | 05:16 PM
so keep my stock gears and go ahead and get a converter? ok i gotcha...which converter do you have? do you like it? and does the aftermarket converter work with a new 12 bolt?
Old Sep 27, 2005 | 05:59 PM
Roarin_8's Avatar
Those questions have been answered, nice talkin with ya and let me know how it goes.
Old Sep 27, 2005 | 06:14 PM
thanks again!
