If you broke a 10 bolt with an A4
Old Feb 10, 2002 | 07:25 PM
Chris Spiess's Avatar
Default If you broke a 10 bolt with an A4
What broke and what was your setup at the time.
TIA
Old Feb 10, 2002 | 08:08 PM
Colonel's Avatar
Default Re: If you broke a 10 bolt with an A4
Spider gears busted. MTI 422 running 10.7s on radial tires. 1.5x 60 ft times. 3500 lb raceweight.
Old Feb 10, 2002 | 08:12 PM
Mike Hoffpauir's Avatar
On my stock 10 bolt I've installed a set of 4.10's that ate up the 1st pinion bearing on there first time at the track. I just changed the fluid on my 3.42 setup the other day and noticed i had a slight chip in the ring gear (about 1/8" by 1/4"). I was running 12.0's on the 4.10's, and my car has been as quick as 11.59 on the 3.42's.
Old Feb 10, 2002 | 08:46 PM
JS's Avatar
JS
Everything but the axles were toast
Launch was a 1.50 60ft that killed it
JS
Old Feb 10, 2002 | 09:25 PM
Bobby C 01TA's Avatar
first time i've heard of this many 10's going out in A4's.. i've seen cars doing 10's all the time back to back with factory 10's.. dam.. the luck i guess.. i might re consider the convertor lol
Old Feb 10, 2002 | 09:26 PM
Oh, I forgot. I did bend an axle with my vig#7 3.23 combo. The car was running 12.0's@112 at the time.
Old Feb 11, 2002 | 11:22 AM
Colonel's Avatar
Bobby, it depends largely on track condition and suspension. Wheel hop kills rears with A4 cars just as it does with M6 cars. That's what got mine. I hooked HARD out of the gate but then about 20-30 FT out, the tires started to wheelhop pretty badly. That rapid on, off, on, off pounding from the wheel hop did it...NOT the initial launch. The track and suspension just wasn't quite good enough at that point to keep 'em planted.
BTW, that was with an Auburn differential and stock 3.42 gears (it came out of an M6 car.)
[ February 11, 2002: Message edited by: Colonel ]</p>
Old Feb 11, 2002 | 11:40 AM
Raughammer's Avatar
D(irecto)r Pepper
If you use soft tires. You should have little problem.
If you use radials.... man, that is a death sentence for the rear.
I havent used radials at the track since I got my FIRST converter. I have never run this car at the track with radials & an aftermarket converter.
Wheel hop will KILL an A4 rear end.
If you stay away from the whole radial thing.... your rear end "should" live a long healthy life.
By Brett Foote | 2026-06-04 05:00:17
