Very strange trans problem,HELP!!!!!
I have had this issue with my GTO for a few weeks now.I removed the verter,installed verter,retuned and everything was fine for 1000 miles..
Then I get the dreaded P0757 code which sometimes happens with vertered cars...So no biggie I turn it off via my edit and everything is fine but now all of a sudden I come to a light in stop and go traffic and the car feels like its slipping in 1st,It will shift fine but again its slips in 1st just like I had the PO757 but how can that be if I turned off the code?
Could that noid be failing,I read a TSB about noids going bad in our trans causing this to happen or something to that effect...
Its driving me nuts,I turn the car off come back and the cars fine for 3 days then boom it does it again...
JS you are soooo busted!
Double Post.
Please check out:
https://ls1tech.com/forums/pcm-diagnostics-tuning/398176-help-me-need-help-trans-tuning-issue.html
Double Post.
Please check out:
