Tranny issues!
Old Nov 3, 2005 | 08:07 PM
TA TECH's Avatar
Default Tranny issues!
Here's my prob First and reverse are fine!fluid level fine, no 2nd 3rd or 4th can lock each gear with hp tuners and not move its like its locked 2nd moved maybe a inch or two but had to give it alot of gas in second!Any ideas tranny guru's!
Old Nov 4, 2005 | 10:48 AM
TA TECH's Avatar
No one?
Old Nov 4, 2005 | 03:06 PM
BeachZ's Avatar
Maybe first really isn't working. Maybe you really only have third and reverse, and that would mean your car's in limp mode. Do a search for limp mode and you'll see what I mean.
Old Nov 5, 2005 | 06:29 PM
TA TECH's Avatar
No sir no third! First is fine didn't you read I locked it with HP tuners! Plus when it is put in manual 1st its fine it will go to red line around 40ish mph!Plus codes would be in it if it was in limp mode usually! Took the pan off today and looked clean all that was in the pan was some small peices that looked like thick peices of aluminum foil. one like super small peice that was flat and had a little of a bend at the end!Guess I'll have to see what chuck says mon!Sense not to much tech is going on in the tanny section!
