trex plus 4k stall with a 2.2 str enough?
Old Nov 9, 2005 | 07:46 PM
eric01ss's Avatar
Default trex plus 4k stall with a 2.2 str enough?
So i getting a fuddle stall with a 4k stall speed and a 2.2 str and want to run a trex in the car will it be enoguh and i have 3.23s
Old Nov 9, 2005 | 08:40 PM
slowredz's Avatar
Put some 4.10s in and it will be better
Old Nov 9, 2005 | 10:07 PM
Cop Car's Avatar
my friend (s346k) has a 4k stall in his car that has 3.73s and he wishes he went bigger already
Old Nov 9, 2005 | 10:34 PM
SUX2BU's Avatar
If you wanna go supafast you better go bigger.
Old Nov 9, 2005 | 10:46 PM
eric01ss's Avatar
well looks like i will be doing the ms3 instead so the stall will be plenty and i actually probably going to get a 4k with a 2.4 str yeah
Old Nov 9, 2005 | 10:54 PM
Jpr5690's Avatar
4.10 gears and a 2.0 str for street tires (nittos) if you are gonna be on slicks then mabye a 2.5 str
Old Nov 9, 2005 | 10:56 PM
Jpr5690's Avatar
id base the str on tire selection and the stall speed on cam requirments make sure you dont over do it on str if your not using slicks but also make sure u have as much str as you can use... my ssf3500 is great but being im on 315-35-17 nittos its a bit much now if i had some slicks id be just right
Old Nov 10, 2005 | 08:27 AM
eric01ss's Avatar
For tires i will have et streets and the cam i will be going with wont be trex it will be either the ms3 or f14
Old Nov 10, 2005 | 08:33 AM
monicaz28's Avatar
I would do a 4400 stall and 4.10's
Old Nov 10, 2005 | 11:47 AM
SUX2BU's Avatar
i like your thinkin. See even a girl knows how to set up these cars to go fast.
Old Nov 10, 2005 | 12:37 PM
Cop Car's Avatar
id stay away from 4.10s unless you have a built trans. OD has never historicly been good
3.23s is where id stay
Old Nov 10, 2005 | 12:49 PM
monicaz28's Avatar
It's probably because of all the great teachers I've got around.
Old Nov 10, 2005 | 01:40 PM
Jpr5690's Avatar
yea dont try to race into 4th too much if you want more top end then 3.73 is a good gear.. im thinkin with the et streets you should be good with a 2.5 stall but it may be still a little bit high but hell i have a 2.5 str and i run 315-35-17 nittos (but like i said i gotta ***** foot it out the hole or ill burn them)
Old Nov 10, 2005 | 02:00 PM
2MuchRiceMakesMeSick's Avatar
Im with monica and juan.
4.10s + 4400 + trex
