Q:trans shop owners /builders
Q :what stall and what diameter converter and brand would you recommend?
This was ment to be kind of a general senerio question,hope the same with the answer.Thanks to all that respond.This could have been in the truck section but this is were the trans pro's hang out.
Im wondering if converter builders that dont build trannys will give different answers.
Here is another thing,a un-named converter builder claims his 3000 stall can handle all towing tasks because they have a special custom built oversized clutch disc.OK fine when its locked up but when pulling hills the converter is not always on,if the converter is not on pulling a long steep grade loaded ,seems that unit will get dam hot quick with a 3k stall unlocked.Coolers can only do so much,disapate heat,bigger coolers just do it a little sooner,they are not a band aid to a bad set up.
Welcome all responses,feel free to disagree.
It was not yank that I was reffering to.My 2400 has been the idea converter for the why I use my vehical.I tow 5Klbs all the time.Several time a year I tow the travel trailer and quad in the truck,everything loaded people included its right at 13.5K LBs.Here in the high desert we have lots of long steep grades.This Yank has done a great job and the fluild has never even slightly dicolored.(maintance helps) All I am saying is I believe this 300mm 2400 Yank is as far as I would go with these kinds of loads on a 4L65e
I have towed over 11K lbs with my 2600 stalled 8.1 test truck for over 56K miles with no overheating or trans oil changes with no issues
If you go to a smaller converter size (245mm) when it comes out of lock up on a grade or passing the RPM's will jump up fast, this is a item that some owners do not want to deal with.
Good luck in your choice
call us for more info
775 826 9955
775 826 9955
