View Poll Results: Built 4L60E vs. TH400?
Built 4L60E
197
44.37%
TH400
247
55.63%
Voters: 444. You may not vote on this poll
Old Jul 23, 2006 | 10:07 AM
  #81
Honda Hunter's Avatar
Originally Posted by JL ws-6
Good luck with 700 rwhp and a 4l60.. I dont' care who guarintee's what, it's not gonna take it period. Sure you can run one, if you like taking it out and sending it back probably every 4 passes down teh track, or 1500 miles.
I'd think about the TH400 swap... and unless you REALLY need the gear vendors unit.. I'd skip that as well. A converter that's just right, and the right rear gear, and it's not as bad as everyone thinks. Besides... I don't think that the gear vendors will hodl up to that kind of power all to well either.
Unless you daily drive the car, or drive alot of long distance trips, a 2.73 geared TH400 setup on the street won't be that bad. And if you do daily the car... what on earth do you need 700 rwhp for LOL!
What proof do you have of what the GV can handle?
Old Jul 23, 2006 | 10:16 AM
  #82
Oh, also forgot nto mention what a great thread this is. It answered every question I had just about. A big part of me want to go th400 but I just cant imagine cruising on the highway above 3000 rpm's in 60 lol. I know some companies make a lock up kit for the th400 but I dont have alot of info about it. It was one of the few things that wasnt discussed in this thread.
Old Aug 30, 2006 | 10:42 AM
  #83
b00sted's Avatar
Do you guys think people just didn't drive on highways before the Overdrive came along?
Th350's and 400's were stock transmissions in alot of cars.
Driving at 3000rpm on the highway is fine for you motor...There's no major load on it just cruising down the highway...It'll be just fine.
Old Aug 30, 2006 | 05:02 PM
  #84
cws T/A's Avatar
gas was 70 cents a gallon then . now 93 is $3.00 a gallon Ive had a DD with 4.10's,
th-350 not bad in the city or the highway 4000rpm 70+mph but it will get old quick. We have a gearvendors holding 700 hp. the gas milage went from 10mpg highway to 16mpg with it. It bolts to the end of your transmissions outputshaft . thedriveshaft gets shortened also so its {stronger} . Only downfall is geting it to fit . We had to BFH the floor board .
Old Sep 5, 2006 | 10:31 PM
  #85
Loadre's Avatar
The GV unit is rated at roughly 1200 horsepower FYI.
Old Sep 6, 2006 | 08:22 PM
  #86
chris718's Avatar
did anyone take the time to view this link i posted?any comments or questions?http://www.ckperformance.com/gmaodpic.html
Old Sep 6, 2006 | 09:28 PM
  #87
sleeperstyle's Avatar
im slightly interested in the ck hybrid trans (but price $ not listed...?). pm me any relavent info... main question- how do you adjust the shift points in it? im guessing seperate trans computer ?(more $?). how do you adjust the lockup also. can it handle spraying out of the hole and through the shifts- say a 10.0 car on juice with ALOT of torque?
as far as going with a 400, well i drive REALLY ******* FAST on the highway, like i cruize at 80-90mph so no lockup and no od is out of the question for me at this point. **** i drive faster than 60mph alot of the time.
can't go on replacing 4l60e's forever though, and im in the same boat as alot of these people- gonna buy a built trans SOON but don't know quite what yet...
Old Nov 4, 2006 | 05:12 PM
  #88
engineermike's Avatar
Originally Posted by MountainMotor
Say both are rated to hold the same amount of power for now.
You can't start such a Poll with a ridiculous statement like that and expect resonable results. That's sort of like the guy that posts the Poll "LS1 vs. SBC" on the friggin' LS1Tech site!
The 2 trany's are soooo far apart in the power holding capability and THAT should be the MAIN thing considered when comparing these 2.
Mike
Old Nov 10, 2006 | 07:09 PM
  #89
B18CYA's Avatar
Originally Posted by blkZ28spt
Right now I get 11-12 mpg around town. That means I use almost $6 in gas going to and from class every day. If I had known how much gas would cost now and how much my modifications would hurt my gas mileage I would have modified my car differently. As it is I am hoping to hurry up and graduate so I can buy an econobox to drive daily, given our ridiculous gas prices.
YIKES! my BB olds with a hp 950 gets around 9
i was hoping i could pull off around 15-18
what do you get on the highway?
what gear and tire size are you running again
anyway my vote goes with the th400 .
my car was a4 toasted one went to a m6 and now going with a L92/402 and know the center force wont hold.
Old Nov 20, 2006 | 12:30 AM
  #90
GREAT_WHITE's Avatar
Originally Posted by ZeeDaddy
This is true for a stock 4L60E. I just rebuilt my 4L60E for the street with parts that can handle 650hp. How much money do you have? We can build a 4L60E that can take 850hp.
WHERE YOU WORK AT ?????
KRIS
Old Nov 20, 2006 | 12:47 AM
  #91
performabuilt's Avatar
LS1Tech Sponsor
While a 400 is strong for overall drivabilty and performance ill take a 4l60e any day and yes those hp figures are atainable with the 4l60e
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Jan 16, 2007 | 12:02 PM
  #92
J2Pharren1's Avatar
this should be stickied.
Old Jan 16, 2007 | 12:16 PM
  #93
BadAssFast's Avatar
Originally Posted by imslow
you think the TH400 is lighter than a 4l60e???
Thank you.
I recently went from 4l60e to TH400...I have full manual reverse valve body and a ratchet shifter. The combo works great. Fuel consumption is an issue. The 4l60e was built to be a kitty cat/feel good transmission. The Th400 is more like a freakin Puma. It shifts fast and hard.
Old Jan 16, 2007 | 09:06 PM
  #94
mullenh's Avatar
Originally Posted by BadAssFast
Thank you.
old school answer here anything that can be done to the th400 can be done to the l460e. a guy in my shop drag races the th400 but he is very pro on the l460e and preferrs it over the th400. he also rebuilds transmissions for a living.
Old Jan 17, 2007 | 10:53 AM
  #95
BadAssFast's Avatar
So you submit that a 4l60E can be as strong as a TH400? Maybe a 4l80E but not a 4L60E as far as I know.
Old Jan 21, 2007 | 10:32 AM
  #96
XpEdItIoUs's Avatar
Thank you.
That's why I bought mine
Old Jan 22, 2007 | 10:36 AM
  #97
Xtnct00WS6's Avatar
Why doesn't anyone consider the 4L80e? You have the best of both worlds, it's strong like the th400 and you can drive it on the highway too with the OD.
Old Jan 22, 2007 | 07:45 PM
  #98
BadAssFast's Avatar
It robs a bit more power and weighs a little more, still if you need OD a great choice.
Old Jan 22, 2007 | 08:09 PM
  #99
XTINCT Z's Avatar
You'll be building my level 2 4l60e tranny this winter
Do you guys do a 3800 stall or just 3500 and 4000?
Old Jan 23, 2007 | 10:32 AM
  #100
Roarin_8's Avatar
I have a 3800. I picked the size I wanted (3600) and went 1 size higher.
Aren't those 4L80Es expensive as hell for a built one too? Like 4K if I remember correctly.
