Please HELP with a Yank converter.
Old Jan 13, 2006 | 08:52 PM
Ru2slo_99's Avatar
Default Please HELP with a Yank converter.
We just installed a Yank PE4200 and a transgo shift kit on an 02 Z28. The weird thing is when it shifts under normal driving it seems like the transmission is slipping. Then under WOT it does not go below 4800 rpm when it shifts. What I am asking is this normal.
Thanks
edit: It has 3.73 gears also.
Old Jan 13, 2006 | 09:28 PM
JNorris's Avatar
Moderator
Based on the info provided what you are seeing is typical of any high stall converter. My 4000 is the same way.
When I take off from a stop at say 2500 rpm the RPM will stay at 2500 through all the shifts. At WOT mine rpm drops back to 5400 after each shift.
John
Old Jan 13, 2006 | 09:33 PM
Ru2slo_99's Avatar
Thank you so much,IT locks up and it's fine, killer in first but the rpm do not fall below 4800 to 5000. I that it was normal thanks again.
Old Jan 13, 2006 | 09:45 PM
JNorris's Avatar
Moderator
What RPM does your motor turn when leaving from a stop light and keeping up with the traffic?
Old Jan 14, 2006 | 12:11 AM
Ru2slo_99's Avatar
About 2500, drove it some more and it feel great. I hope to get in the 11's it ran 12.40 at 113 last weekend.
Old Jan 14, 2006 | 01:46 AM
Drew778's Avatar
My Yank SS-4000 is killing me, I'm going back to a lower stall for nitrous.
Old Jan 14, 2006 | 10:51 AM
Yank's Avatar
move the low speed shift points up a few hundred RPM, that will help take out some of the slip out
Old Jan 14, 2006 | 11:57 AM
Ru2slo_99's Avatar
One more ? when it shifts in to 2 gear, normal driveing it does not start pull till 3000 or 3500. You can pull it into 2 out of drive rolling and it will pull like hell, the only time it feels funney is from a stop when it shift into 2. at WOT it spins 1 then shifts and spins 2 so I don't think it's slipping it's just a 4200 stall, what do you think?
