Drivetrain BANG
I don't think the tranny mount is busted since it would probably do it if I floored it from a roll. Would loose rear torque arm bolts cause this?
I just did poly motor mounts with my header install, and the transmission/converter are next in line to upgrade. While it is out is it worth it to do a poly motor mount?
I've heard nothing but good things about poly motor mounts...I think I'm gonna install them when I do heads/cam.
then got true duals, and I have no complaints about the mounts,
but now with the exhaust, the console will vibrate, and it's worse when it's cold out,
good thing I'm in Fl,
pat
