How do you properly bleed a newly installed Adj master???
Just a few things, I wasnt bleeding by myself. I had my roomate pump the clutch about 20 times, hold it to the floor, I would crack the bleeder valve, close it an repeat the process. I have good pedal pressure at this point. I push it down and about 2 inches down I can feel it ge harder, then thatswhere the clutch feels like it should engage. I start the car and it wont go into any gear. I turn the car off and I can shift through every gear. Thats what led me to think it was the master in the first place. Any other ideas??
Can you get your buddies @ RP to help out? They had the same problem with my mcleod and new slave, and stock master, that you had. It wouldn't disengage or engage all the way. I overnighted the ADJ master from cartek (stock master with a tie rod end looking adjuster rod) it was still a little rough, but I adjusted the rod on the cartek master out about 1/2" and it works fine now. Whatever method they used to bleed it appears to work fine in my car. Just a thought.
Interesting information I would have never thought of this. (Being filed away for future reference.)
BeaSSt please let us know how it gets fixed. Also did you mod the floor pan? if so did you get close to the bleeder valve?
<small>[ March 21, 2002, 07:03 AM: Message edited by: 2000 Camaro SS ]</small>
<strong>Ahhh so definite engagement problem. I really concentrated on the "feeling" of my pedal today. it feels "normal" (not any real resistance till almost halfway) then you can feel it get more resistance. Not that it really helps ya but just thought I'd give you something to compare to. You surely have it bled properly by now. Maybe the pp is bad. Mine took like 10 minutes total to bleed the 2nd time around. I also remember being able to actually HEAR the slave//pp when the pedal was being pushed down and i was under the car. It was faint but i could hear it</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Jerry, I can hear the slave being moved forward when Im under the car. That leaves me to believe I might have a bad PP. Everything seems to be leading in that direction Im headed out now to find out now.
