Why not lock the converter in 2nd gear?
I always read about locking it in 3rd gear on the big end. Has anyone tried locking it in 2nd gear? It just seems to make sense if you pick up 20 hp by locking it, why not in 2nd?
LS1 Tech Administrator
You can, but you'll need to unlock the converter before the 2-3 shift to take advantage of torque multiplication from the converter. I will be experimenting with this with LS1 Edit in the future. There was a huge thread about this a few months ago. Do a search under my username. Don't expect to gain 2 tenths though. You will only be gaining 20 rwhp in short bursts during the 1/4 and not during the entire run. The high stall torque converter is better than a locked up clutch until about 5500 rpms. That window from 5500-6500 in 2nd gear goes by really fast. The window is longer in 3rd provided you're running enough gear to take advantage of it.
__________________
![](https://ls1tech.com/forums/signaturepics/sigpic210_1.gif)
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
Found the link. Try this: https://ls1tech.com/ubb/cgi-bin/ulti...c;f=2;t=000689
__________________
It's no sweat if you use one of Yank's oversized Kevlar clutches (like come in the Extreme converters)...they're much better than the heavy heavy multi-disc set-ups used by other companies. Kevlar is nearly indestructable and the single clutch keeps the weight down and the clamping lbs per sq in very high. It works!
__________________
