HELP! installing vig 3200/ remove check ball at end of input shaft?
Old Mar 18, 2002 | 04:12 PM
highgmc's Avatar
Default HELP! installing vig 3200/ remove check ball at end of input shaft?
I am reading my instructions that came with my vig 3200, they say " remove the check ball found at the end of the input shaft. This modification allows the converter to operate with a firmer (yet not harsh) converter lock up. This is an optional modification. MAKE SURE O-RING IS INSTALLED ON INPUT SHAFT.
should I remove this check ball?
Old Mar 18, 2002 | 04:18 PM
AndUAndI's Avatar
Default Re: HELP! installing vig 3200/ remove check ball at end of input shaft?
I did not remove mine. Mike (Yank) never made such a recommendation.
I have a TransGo kit installed with their fix for the converter lockup, so the clutch lockup is just right!
Old Mar 18, 2002 | 05:30 PM
Patrick G's Avatar
LS1 Tech Administrator
Don't do it. The check ball is there to equalize the pressure spikes that happen with the tranny. When you remove the check-ball, your converter can experience all kinds of funky problems with the drastic fluctuation of line pressure.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Old Mar 18, 2002 | 08:44 PM
red ws6 99's Avatar
I think the instructions for the vigilante for our transmissions says to not remove the ball. I did not either way.
Gary
Old Mar 18, 2002 | 11:34 PM
M_Minnick's Avatar
I installed a Trans-Go kit into a brand new GM tranny, and had it installed about a month and a half ago. I transferred over my Yank ST3800 which had never had any lockup problems since I installed it a year ago. I now have serious lockup issues! As the converter goes into lockup, it shudders badly, and once in lockup, any light throttle input will cause it to shudder.
I contacted Dana @ Pro-Built Trans., who I purchased the Trans-go kit from, and the first thing he asked me was if I had removed the check ball. I told him no, and that I have never even heard of doing that. It was not stated in the Trans-Go instructions, nor was ever mentioned by Yank. And being on these boards daily for over 3 years, you think it would have been brought up before. I have yet to contact Mike @ Yank, but I am afraid that will be my next course of action.
Is my lock-up clutch shot? The converter is still under warranty, although it will be a hassle to remove it and wait for it to be repaired. What part of the Trans-Go kit deals with the converter lockup issues? The instructions don't really specify what each modification does.
Thanks,
Mike
Old Mar 19, 2002 | 08:17 AM
Patrick G's Avatar
Mike,
I don't see how your converter can be at fault if it had worked flawlessly for over a year. Sounds like there are transmission factors that are making it do this.
Patrick
__________________
Old Mar 19, 2002 | 08:33 AM
Ragtop 99's Avatar
Mike,
If the converter wasn't shuddering in your other car, then it is not the converter. Sounds like your pressure is down and its not holding the lock-up clutch on. You might try putting a presure guage on it and see what it is reading at lock-up and compare it to spec.
do you have any other mods or programming done to your car?
Old Mar 19, 2002 | 10:20 PM
JimmyKash's Avatar
i remember some people saying that removing the screens screws with the way the computer controls the tranny line pressure
Old Mar 20, 2002 | 12:10 AM
M_Minnick's Avatar
Other mods consist of: FTRA, HPP3: No tuning, fan, rev limiter and shift points only, cutout, Direct-Flo, stock maf w/o screen.
I don't believe any of these would have an effect on line pressure.
I work at a GM dealership, so hopefully I can recruit out trany tech into hooking up a gauge and going for a test drive.
Thanks,
Mike
