Stuck trans dipstick
Old Feb 14, 2006 | 12:12 AM
Jon2kZ's Avatar
Default Stuck trans dipstick
Ok I'm a noob to the 4thgen but this looked pretty simple, pull up the lever and pull out the dipstick, except the thing won't budge. The lever moves up & down but the darn dipstick won't pull out. I've tried pulling harder, twisting but I don't want to break it off. How does this darn thing come out? Of course the manual just says flip up the handle and pull it out..duh. Help! I want to change the fluid soon.
Old Feb 14, 2006 | 12:34 AM
GDM Z28's Avatar
mine does the same damn thing....when i pulled the motor out i noticed the tube was suqashed......dont pull it out because its a bitch to get back in...just change the fluid.
Old Feb 14, 2006 | 09:47 AM
Jon2kZ's Avatar
Is there another way to get fluid back in it? I thought the only way was to refill it thru the dipstick tube.
Old Feb 14, 2006 | 11:03 AM
outkast6991's Avatar
i had to yank on mine pretty hard when i first got the car.when i got it out i put a very light film of vaseline on the seal and it has never stuck again.the only way i know of to put fluid in is through the dipstick.good luck
Old Feb 14, 2006 | 10:20 PM
Jon2kZ's Avatar
The previous owner had it serviced at a EZ Lube close to here, I think I'll take it back there and play dumb and ask them to show me how to check the fluid. If they give me any trouble I'll tell them to check their records and see that they were the last to service it 30k miles ago.
Old Feb 14, 2006 | 10:27 PM
GDM Z28's Avatar
30k is a long time ago.....is it stuck at the top? if so just hold the tube with one hand and twist it side to side and yank. hold the tube so you dont pull it out of the tranny.
Old Feb 19, 2006 | 03:22 AM
Jon2kZ's Avatar
The EZ Lube guy pulled and twisted pretty hard on it for a minute and it finally came out. The rubber seal at the top was just bone dry and really stuck. Once out I smeared a some trans fluid from the stick onto the rubber seal and now it's working perfect again.
Old Feb 20, 2006 | 10:39 AM
Bharnz's Avatar
Yup had the same problem with mine. a little lubinal worked great.
