4l80e swap info
[QUOTE=8a8mfh]I weighed three converters, drained. Stock 4L80E is 64, stock 4L60E is 46, TCI SF for a 4L60E is 30 pounds.
QUOTE]
I weighed my 4L80E 9.5" 5 disc Vig and it was 36lbs with some fluid in it.
QUOTE]
I run mine with no bottom cover. It gives better cooling for the converter. The biggest thing I noticed when going 60 to 80 was the first gear ratio. I don't notice any handling differences between the two.
Originally Posted by DEEZ98Z
I went with the same shifter. It fit under the console great and actually Dutch who I got the idea from Here is a pic...
Rachet shifter
I never wieghed my trans. I know it is heavy BUT it has 4 gears and it will hold Thats all I care about
Rachet shifter
I just picked up a '99 core, it has a top bolt, never knew that. I also have a '98 trans in my silverado that has no top bolt.
So I guess you can bolt one up using all eight bolts.
Also, that first gear in the 4l80e, its a bit longer right, how did that change your driving....
Originally Posted by obZidian
HAndling differences? Do you mean how they hold the power thrown at it.
Yes, the 4L80E has the 2.48 first gear in it so it doesn't seem to hit the tires as hard in first gear. You can get the 2.75 first gear put in if you want though...
I weighed my 4l80e without the converter and it weighed 178 I believe. I'm not sure if this will help save anyone some money, but I modified my stock 6 speed crossmember to work with the 80e, but it took a lot of cutting and welding to get it perfect. I'm still looking into the tranny cooler lines, because I can't figure out how to get them connected to the lines running up front. I wish they didn't have that o-ring on them so I could just run a normal pipe thread fitting out of the tranny!
Brian
Brian
Sorry to bring up an old thread. This one has alot of good info though.
Cablebandit: IS the HPTuners software able to run this trans yet with my 98 Z28? I really need to know weather or not I am gonna have to buy the TCI software.
#36
Brian
Brian
#37
So, all i would need to do is send out my HPtuners tuning software or my pcm, to ken at hptuners and he will be able to do the swap? How much?
I guess i would also need to computer harness as well for the 4l80e swap.......
#40
trhe fourth gear or o/d gear in the 4l80e is larger than the 60e/65e, right? Therefore, we will be running higher RPM'z at the same speed with the same rear gear.
What gear do you guys recommend i could run with this trans with a 3400 4l80e converter?
