To get a shift kit or not to get a shift kit.... that is the question
Old Feb 24, 2006 | 09:00 AM
Superman09's Avatar
LS1Tech Sponsor
Default To get a shift kit or not to get a shift kit.... that is the question
So im going to be ordering a stall here soon, i have decided on a 3500 2.0 Fuddle for my street driving. Car will be driven on the street only. Im ordering the B&M 24k cooler as well and a trans temp gauge. What are the real benefits of the shift kit and should i get one or not? Id really like saving $115 if i dont need one, but if it will help the performance and life of my trans, it will be worth it.
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
Old Feb 24, 2006 | 09:23 AM
Dustin 98TA's Avatar
I would get it. With the stall, your shifts will feel sloppy if left stock, a shift kit will firm them up a good bit.
Old Feb 24, 2006 | 12:26 PM
Superman09's Avatar
LS1Tech Sponsor
but will it throw more wear and stress on the trans. I get a lot of mixed views on this subject.
__________________
Old Feb 24, 2006 | 03:08 PM
Actually it will be better for the trans, the clutches wont slip into gear anymore.
Old Feb 24, 2006 | 08:13 PM
Superman09's Avatar
LS1Tech Sponsor
ok.... trans go my best bet?
__________________
Old Feb 24, 2006 | 08:38 PM
Scotty-Z's Avatar
Most definitely. Wouldn't go with any other brand.
Old Feb 24, 2006 | 08:56 PM
273sunsetZ's Avatar
I thought you could change your shift points without a shift kit. Everyone I've talked to that knows transm. tells me to get it done electronically.
Old Feb 24, 2006 | 09:39 PM
Automatics's Avatar
Restricted User
The "modified" Trans-Go Performance Shift kit that I use, will give you smooth part throttle shifts (which is easy on the gear train) and quick & firm shifts at WOT (this will keep the band & clutches alive). If the shift kit is done right (matched to the rear end gear ratio, motor, torque converter, & how you drive) it can have long lasting beneficial effects.
Old Feb 25, 2006 | 05:07 AM
Superman09's Avatar
LS1Tech Sponsor
How do i get the modified one and what does it cost?
__________________
