Need Help With Torque Converter
Old Feb 27, 2006 | 08:36 AM
00onyxSS's Avatar
Default Need Help With Torque Converter
OK, here are the question. First, if a transmission is slipping is it possible to be the torque converters fault and nothing else wrong with the transmission? Second, if the problem really is the torque converter, (which is an aftermarket on mine) how do I know what to swap it out with when I want to buy a new one. I mean are there different sizes and things like that? I know mine is a 3000 stall but that is all I know about it. If I just go to a converter site for example do I just look at what the horsepower rateing is for the converter when deciding? Thanks for the help.
Old Feb 27, 2006 | 08:46 AM
jimmyblue's Avatar
Moderator
Slip in overdrive is more likely the converter (if it's a small
diameter aftermarket one) than anything else. Especially
at low-moderate load. The horsepower ratings mean nothing
to low-load clutch slippage although a converter with a
clutch rated to lock at WOT, is likely beefy enough. This
is what moved me up to the "Street Performance" series
of Fuddle converters, the clutch. Every model at every
mfr can be different, you need to put the question to them.
You really have four key selection parameters, two of which
get common mention; stall speed, STR, efficiency and the
clutch strength / durability. Note that some converters for
extreme drag lockup use, use clutch materials you might
not like on the street (good grab at WOT, may chatter at
very light applies). Take your time with the applications-
line folks and get your needs figured out.
