Ran Into a Few Problems
Old Nov 6, 2006 | 08:39 AM
performabuilt's Avatar
LS1Tech Sponsor
There will be a code present during limp mode ,First determine if there is a code setting if there is corect whatever condition it indicates , if theres not a code then heres some electrical fault causing loss of B+ to the trans and the wiring plugs grounds will need to be checked
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Nov 6, 2006 | 07:32 PM
BubaGumpShrimp's Avatar
its the po751 and po757 for the 2001-2002 cars that needs to be turned off. For the earlier cars its something like 18xx or something like that, ill try and find it for you
