Tranny Smart Guys, POWERGLIDE ?
Here is my question.. All the big dogs run powerglides at the track.. has anyone run a powergluide in a F body? What needs to be done to make this work that didnt need to be done for a TH350 or TH400?
I if i blow this tranny this season, id like to start thinking about other options.. I am welcome to opinions on this..
How heavy is your car?
How much power do you plan on making?
Basically, If you don't plan on running well into the nines don't bother.
That is the kind of power to weight ratio you need to be looking at before you start considering a Glide.
Up to that point you are better off with the T-350.
Yes, the T-400 is stronger, but it takes more HP to turn it and it is just plain heavier.
The T-350 built properly, can take you reliably into the 9's no problem.
Jim C.
