Converter causing weird ( low ) idle?
Old Apr 4, 2002 | 07:23 PM
SuperZ28's Avatar
Default Converter causing weird ( low ) idle?
When I am at a stop light, it sometimes feels like my car wants to die, I see the tach kinda fall, then pick up again...this started right after my converter went in.
It's never actually died, so I'm not even sure if it's anything to worry about
could it just be a spark plug problem?
thanks for the help
Alex
Old Apr 4, 2002 | 07:26 PM
98TAauto's Avatar
Default Re: Converter causing weird ( low ) idle?
its just the smaller size of the converter... some cars learn it and get it straight after a while.. but others dont.. somtimes mine you idle like 500-600
but i raised it to 700 on ls1edit in gear <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Old Apr 4, 2002 | 07:57 PM
Ragtop 99's Avatar
Try the pcm relearn procedure. If that doesn't work, turn your TB idle set screw about 1 turn and see if that raises your idle enough to cure it.
Old Apr 4, 2002 | 08:06 PM
SuperZ28's Avatar
Thanks for the help
I'll give it a shot
Old Apr 4, 2002 | 11:16 PM
Loco's Avatar
I had the same problem after putting in my Yank 4500. I Turned the idle screw a couple of times and it fixed it. Be careful not to turn it too many times or it will throw a code.
