Getting a TCI 3800...Tune???
thanks
Make sure you install a good cooler with that streetfighter before you drive it.
As for local shop's in your area someone will point you in the right direction.
Have fun!
and why do you think i'll hit the rev limiter?
sorry som many questions..just trying to make sure i'm doing the right thing, and understanding everything too..
thanks
thanks
Here's an example: https://ls1tech.com/forums/showthrea...41#post4632441
rpm's. The reason I think you will hit the rev limiter is because that seem's to be pretty common from the guy's on this site that have stall's rated from around 3400 on up.
I have a fuddle 3000 with a 2.0 str and didn't need a tune with mine. Seem's to shift right around 5800 to 5900 rpm every time.
I have read of more then one person who said their car was just fine after a 3500 stall upgrade, but that seem's to be the exception rather then the rule.
At any rate, install it and give it a try. If your shifting at or above 5800 rpm and before you hit the rev limiter you will be fine.
