Old Apr 25, 2016, 05:30 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Tranmission Guides
Print Wikipost
Transmission removal, NEED HELP!
Old Oct 10, 2009 | 01:33 PM
woodsls1's Avatar
throw the torx converter bolts in the trash all there good for is stripping out . Buy new ones u will be glad u did
Old Oct 10, 2009 | 01:35 PM
woodsls1's Avatar
throw the torx bolts in the trash and buy regular bolts u will be glad u did. As for the top trans bolts there not that bad with the right tools. I have had mine out like four times in 3 months
Old Oct 12, 2009 | 05:15 PM
Gatsby's Avatar
I don't have the top 12 o'clock bellhousing bolt in. Not a problem. Leaving two bolts out? I'm not that brave.
Old Oct 13, 2009 | 06:42 PM
DemonInside's Avatar
a tip to get to the top bolts on the t56 or 4l60e you can loosen the engine cradle bolts since they are pretty long and bring the cradle down a inch or so, helps out alot!
Old Oct 13, 2009 | 08:18 PM
01ssreda4's Avatar
3 1/2 years.....Im sure he figured it out
