3400 TC installed,
Old Apr 17, 2006 | 05:20 PM
Bharnz's Avatar
Default 3400 TC installed,
Happy with the throttle response,
BUT
horsepower went from 347 to 324.
tires spinn like crazy, cant get any traction, and my 1/4 mile time went from 12.4 to 12.9 have TA drag radials, and had it dyno tuned
What can I do???
times were done with both Vector FX
and the new G tech.
Nice thing is it will roast tires at any speed, and NO dead spot at 40 mph on up.
She will leave marks on the road when I punch it at 70 mph.
Kinda happy , Kinda not.
Old Apr 17, 2006 | 05:27 PM
blown 346's Avatar
You will loose HP no matter what when you get a convertor.
Old Apr 17, 2006 | 05:30 PM
Bharnz's Avatar
Guess I'll just have to get slicks.
Old Apr 17, 2006 | 05:35 PM
1999Z28's Avatar
so you run on 18s at the track..but have mickey thompson's otherwise? that doesn't make sense.
Old Apr 17, 2006 | 05:57 PM
Bharnz's Avatar
Its just an old air strip and I usually run the mickeys.
I was thinking the ta's would be just as good.
Old Apr 17, 2006 | 06:40 PM
1 BLOWN V8's Avatar
I am putting down over 400 to the ground and have a 3,200 stall. I get 1.6-1.7 60 foots all day long and the car hooks hard at any speed.
My set-up is: Lower control arms with relocation brackets, adjustable panhard bar, weld in sub-frame connectors and 17X10 wheels with 315/35/17 Nitto drag radials.
Old Apr 17, 2006 | 07:09 PM
Bharnz's Avatar
Sounds great........... no internal engine parts, yet
I have welded in sub-frames and lower control arms,
I'll have to try the adjustable panhard bar,
Thanks
Old Apr 17, 2006 | 07:16 PM
1 BLOWN V8's Avatar
Thanks
Also did you lower your car? If so get the relocation brackets for the lower control arms.
Old Apr 18, 2006 | 11:09 AM
Bharnz's Avatar
Sorta afraid to lower it, X pipe and three inch exhaust,
