difference between PI3200 and SY3500?
Old Apr 22, 2002 | 06:03 PM
Ls1 382ci SS's Avatar
Default difference between PI3200 and SY3500?
like the title says. anyone go from the PI 3200 to the SY3500? which one would be better for a 250 shot of n20. I don't want to run the rpm's to high.
Old Apr 22, 2002 | 06:22 PM
Patrick G's Avatar
LS1 Tech Administrator
Default Re: difference between PI3200 and SY3500?
The Vig 3200 is a 9.5" converter (245mm)
2.2 stall torque ratio (pretty high)
Hard hit off the line.
Average top end efficiency
Good for 1.65 60' times in average LS1 F-Body with slicks or ET Streets
The Super Yank 3500 is a 10.0" converter (258mm)
1.63 stall torque ratio (low)
Soft hit off the line. (good for tire limited applications)
Excellent top end efficiency
Good for 1.80 60' times in average LS1 F-Body with drag radials or possibly stock tires
The Super Yank will be better on a big shot of nitrous because of its larger size and higher efficiency which will give it better holding capacity. Its lower STR will soften the brutal hit of a big nitrous shot too.
But a 250 shot? I hope you're not going to try that on a stock 4L60E. It won't last very long. A shot that big would be better served by a purpose-built nitrous converter like a Pro Yank 3400 Extreme. More aggressive stator, Kevlar Posi-Lockup clutch and 6 bolt mounting lugs vs. the stock 3. Good luck
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Old Apr 22, 2002 | 07:20 PM
Pro Yank 3400 Extreme can you tell me about this converters specs like you did above please. this is exactly what I was looking for in a response. you hit it right on the nail. I didn't know it was 6 bolts as opposed to the 3 bolts. and no I won't be running on the stock 4l60e tranny. I will have the upgraded Speed Inc 4l60e. I will use this trans until I have enough money in the future to get a different tranny with a trans brake so I can have a spool instead of a posi. I am in my mid 20's and still working on my 2 degrees and saving up for my Tahoe z71 so I can trailor my SS to the track. thanks for your help.
