Funky Idle after Converter install
Old May 2, 2002 | 06:37 AM
ArcticZ's Avatar
Default Funky Idle after Converter install
I put a TCI Super Streetfighter (3500) in my cr this past weekend and now every time I give it gas and let off at slow speeds the idle will go way low. If this happens when I am going around a turn it will die. Is there anything I can do about this?? I love the converter as this is just about the only problem I have.
TIA
Stephen Heine
Old May 2, 2002 | 07:10 AM
gwj's Avatar
gwj
From: Live Oak, FL - in the woods where the creatures lurk.
Default Re: Funky Idle after Converter install
Two things will help: do the idle relearn and/or turn the throttle stop screw in a tad (takes a torx T15 bit).
I've never had mine die, but I've not been able to get rid of the surging completely. I'm used to it, though.
Old May 2, 2002 | 11:29 AM
Jay 95WS6's Avatar
idle relearn
Jay
www.jayfisherpontiac.com
Old May 2, 2002 | 01:43 PM
Windy City's Avatar
My idle would bounce around and the engine died on my a few times but MAXIMVS is right on, LS1 Edit took care of it.
Old May 2, 2002 | 02:40 PM
MAXIMVS's Avatar
thanks for the backup Windy <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
Old May 2, 2002 | 03:51 PM
Ragtop 99's Avatar
PCM relearn Quick & Dirty method:
1) Pull the PCM BAT and PCM IGN fuses.
2) Let car sit 10 minutes
3) Turn Key to on and then turn off
4) reinstall fuses
5) start engine
6) allow to idle for 2 minutes in park, then 2 minutes in drive, and 2 minutes in reverse.
7) repeat #6 if you have time or if the idle felt rough.
Old May 2, 2002 | 05:01 PM
Trevor @ Texas Speed & Perf.'s Avatar
LS1Tech Premium Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
I just raised the idle via the TB set screw, and all was good. I had my idle sitting at ~625 RPM.
__________________
Old May 2, 2002 | 05:28 PM
Loco's Avatar
I had the same problem when I first installed my Yank. I turned the idle screw a bit and it fixed the problem. Good luck.
Old May 3, 2002 | 12:09 AM
ArcticZ's Avatar
How exactly do i do the idle relearn?
Stephen <img border="0" alt="[Fluffy]" title="" src="graemlins/fluffy.gif" />
Old May 3, 2002 | 12:13 AM
MAXIMVS's Avatar
i've done idle relearn on my car and it still does the same thing that is happening to you man.
the throttle screw i did also...idle raised a tad but doesn't solve the problem either. at least for me.
so i had to buy LS1 Edit. and i'm sure THAT will fix it
